ugh
so...I'm sitting here...had two projects on my plate today. sync the carbs and bleed the brakes.
Bleed brakes...bought speed bleeder syringe thing. Master cylinder just pushes fluid through, no air. When I squeeze the lever only a little fluid comes out. Connect the lines bleed and bleed and bleed. Never develop any pressure at the lever. Tried the vacuum bleeder and the old fashioned method. Only get fluid, no air. tapped all the banjo bolts, no more air. The master cylinder is missing the rubber boot where the lever meets the piston. Am I sucking air through there? Could that be my problem? Do I need to buy a rebuild kit?
Last time I worked on the bike I finally got it to idle at about 1500rpms. Started it up tonight...with choke idling at 2k. Starts warming up, turn off choke...4K removed the throttle cable and it didn't change. Turned the idle knob(feels like it is free spooling now)...no change. I turned in the plot needles until they soft stopped and then turned the out a half turn (thinking then it would only idle if the choke was on) nope, still at 4k. I just can't seem to get it below 4k now
I've sat here and drank 2 Twilight ales and have started on the third. Normally after 2 beers I have relaxed to the point where the answer comes to me...no such luck...
Any suggestions?
Clark
Any suggestions?
Clark
