I have encountered a miss at idle on #1 so will be doing a carb cleaning on my 82 XJ1100. Slowing down from road speed I hear popping noise from exhaust and assume it's due to miss.
I suspect the idle circuit is plugged on that cylinder as it has no ouput at idle removing and grounding the spark plug wire but does at higher rpm.
Factory manual says not to adjust idle mixture screws so when I want to remove them to clean port where do I start to reset them? How do I know they are set right?
Also, I find no float setting as I will be replacing needle and seat assm. on all. I see the part about using clear tube off drain screw but no info on where to get a fitting with proper thread and barb to connect hose. I would like to pre-set the floats closer to avoid having to remove many times to adjust floats.
Does my diagnosis sound correct? Any tips to help me out??
