Hi Gang
Can anyone explain to me how the speedometer gear off the front axle is spose to work.realativey theory. tire Spins the gear
which in turn spins the cable hehhe
When i got my 80 special the speedo worked for a about week then bounced very erraticaly just like my tach does, then speedo died .
So I figured it was the Speedo gauge that was faulty and grabbed another set of gauges off of ebay .(Wrong they both do the same thing as the ones I took off Ive been through the "tach tips" and have just given up on that! even changed out regualtor this morning, and die elctric grease not working either) So anyhow now the other side, the new speedo dont work neither so I checked out the inner cable , its fine both ends are there not broken,so lets go next step, take off front tire the speedo gear,and replaced with another one from ebay tested they say , when I spin the gear by hand I can see where the cable will go inside It will spin,so I take out my inner cable put it in hole and turn gear by hand and the cable will spin, ahh thhis one works right Hmmm so I put new one in bike making sure its lined up proper When i tighten axle down .put inner cable in the open end and then spin the tire and it wont spin the cable ugh ,now im geting upset :0 grab the old one I removed from bike previously and that gear will spin the end of the cable by hand to, so from what im seeing there is nothing wrong with either gear? Or am I 2 for 2 both shot why would they spin bye hand tho,, Do the XS have weak gears that under load they wont spin or something,Gosh seems so simple Front rim shot perhaps.
thanks
Ljay (with no hair left) Only way to tell how fast I go is to ask Cops NO tach No speedo
thanks
