needle jet for BS34-II
  • audijunky
    • Apr 2006
    • 707
    • VA
    So I'm on Bike Bandit trying to order new needle jet(seats) and I do not know which series or size to order. Any one have a clue? I did some searches on the site but didn't find anything. Please Help
    79 XS1100 modified standard
    straight pipe 4-2 exhaust
    Owned 83 Honda V65 Magna
    Owned 02 Vstar 650 classic
    owned 85 Honda Shadow VT 700C
  • audijunky
    • Apr 2006
    • 707
    • VA
    Weel just looked through BB more thoroughly and it appears they dont have ones that fit the Bs34-II. Anybody know where else to look. I checked MikesXS already.
      • 7832
      try partsnmore, the gasket does NOT fit, but the rest does.
      Price is right at $12 each.
      Ray
        • 7832
        Link didn't come through correctly, just go to the bottom of the Yamaha list, and select "go". This is the correct set for the early carbs. The float gaskit DOES NOT fit correctly, but can be used if you punch the two holes out a little bit.
        Needle, seat, and seal DO work well. Don't worry about missing "clips", you don't need them.
        Ray
          Hey Steve,
          BB has their carb parts kinda hidden, they DO have the float valve seats and needles, but they are in the Aftermarket Street bikes, Fuel Air, Accessories, Carbs, Mikun, section, follow this link: Float Needle Seats on BB
          I tried to post a DIRECT Link, but BB's web pages use some ASP type processing, so you have to go to the menu and follow my directions to find it!
          They list 2 sizes, and I don't know which size fits our machines?
          MikesXS also lists 2 sizes, and I vaguely remember someone posting about them getting one size from Mikes, and that they didn't fit, but I can't remember which size they said didn't fit, but I think it was the smaller 10mm size, saying it was too small, but I'm hoping they will read this and repeat the info!? I thought it was JetMechMarty, but I reviewed his posts, and couldn't find any reference to it among them!?
          After doing some research on the parts fiche site, found that the OEM #'s for the XS11 needle valve assembly doesn't match any of the ones I could find for any of the 650's years or models listed by Mikes, so it looks like the screw in types probably don't fit our carbs at all. Only the press in types for the later 80-81 carbs will work!
