running
  • floridajoe
    • Jul 2003
    • 94
    • pompano beach florida
    running
    HI ALL. THIS IS MY PROBLEM. MY 79 S SOMETIMES WILL STATE FINE. AFTER RIDING IT STARTS MISSING AND THEN CUTS OFF. AT TIMES IT WILL RESTART RIGHT AWAY BUT BE MISSING. THE PICK UPS LOOK OK I DO HAVE A 80 S FOR PARTS I AM GOING TO PUT THE PICK UPS FROM IT TO SEE IF IT MAKES IT BETTER. IS THERE ANY ONE PLACE I SHOULD LOOK TO FIX THIS THANKS ALL
    Joe Bjordahl
    “speed don't kill it’s the sudden stops”
    Yamaha xs1100 are addictive
    1979 XS1100S
    1981 XS1100 MIDNIGHT
    1982 XS1100S DONER BIKE
    • 5069
    Other things to check.
    Running too rich and fuel fouling?
    Gas cap breather plugged? Try opening the cap while running.
    Inline filter plugged of maybe gunk collected on the petcock's filter tower?
    Vacuum hose to the octopus is either not connected or has a bad leak.
    Sticking float valve?
    • floridajoe
      • Jul 2003
      • 94
      it does run rich need new boots. went it cuts off there is no spark . i put a new plug in wire no spark.
      Joe Bjordahl
      1979 XS1100S
        Have you checked the kill switch circuitry?
        • floridajoe
          • Jul 2003
          • 94
          thanks for the help once again . changed pick ups new plugs little carb adjust running great thank you again
          Joe Bjordahl
          1979 XS1100S
