Are the right brake rotors for the front and back interchangable on a 81 MNS? I removed my when I had them powder coated and now the front right one rubs against the metal on the brakes, with the piston fully pushed in. So either they are different and I got them put on backwards or I've f@cked something else up. Any ideas? Thanks.
Brake Rotors?
Yes, they are interchangable. You might check how you put the front wheel back on.
-Tighten the large axle nut then
-move the other fork leg side to side until the rotor is centered then
-tighten the two pinch nuts on the bottom of the fork leg.
Some say the front and rear rotors are a different thickness. Could be but I haven't run into this.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example" -
See this link http://www.xs11.com/forum/showthread...ight=alignment
It's about a standard but you can see what I'm talking about and maybe get a few ideas.
As far as I know the rotors are the same.There's always a way, figure it out.
78XS11EComment
