Hi Gang
1980 special: Seems I have a lil pop pop upon decelleration seems to be coming from #1 as far as I can tell, took the spark plugs out to have a look seems that the #1 is a lil black and sooty, (2 3 4 look pretty nice) no carbon buildup at all and the insulator looks pdg, Im thinking its carb related too much fuel or not enuff air? Pilot screw perhaps needs adjusting I hate to bugger with it too much as it sure gets up and goes and dont want to make it worse so I thought I would ask the group ans see what the consensus would be.
Thanks in Advance
Ljay40
Thanks in Advance
Ljay40
you say you dipped the carbs for 3 days! IF you soaked the entire carb bodies in cleaner, then you probably destroyed or damaged the butterfly shaft seals, they are rubber, and don't survive. This will cause a vacuum leak and resulting popping and other unwanted performance issues!!
