Rear caliper sleeve & bushing
  • Filter
  • Rear caliper sleeve & bushing
    I'm rebuilding my rear caliper. Do I need to lube the sleeve and bushing or can I just clean it up and reinstall them?
    80 XS11 SG
    79 XS750 SF
    74 KZ400
    78 KZ650
    78 KZ750
  • #2
    My Clymer manual says nothing about lubricating the sleeve and bushing on the rear caliper.
    Mike Giroir
    79 XS-1100 Special
    • #3
      The manual says virtually nothing about the brakes aside from having your local Yamaha service tech work on them!
      A thin film of brake lube on the bolt, sleeve wouldn't hurt, the caliper slides left/right on that during activation, and would allow it to retract, or at least slide enough to not tend to keep rubbing the rotor when released!
      • #4
        I put brake grease on mine when I rebuilt them. They work great now. I would suggest to put the grease on them.
        MaximRider
        The only known XJ1100 Interstate
        • #5
          Thank You Gents,
          I guess I'll be picking up some brake lube.
          80 XS11 SG
          79 XS750 SF
          74 KZ400
          78 KZ650
          78 KZ750
