XS1100 Idle jet setting?
  • RanMan
    • Apr 2006
    • 22
    • Glen Burnie, MD
    Hey All,
    I've done the main jet adjustment and found that the idle jets range from 3 turns to 5/8 turn. This seems pretty strange so I'm asking what's a good starting point for these? These were virgin carbs and I've just uncapped the idle jets.
    Thanks, Randy
    Love Affair since 1983 with my 1980 XS1100 Special, Blackie
  • GNEPIG
    • Apr 2005
    • 1657
    • fl
    .. a good starting point would be 1 and 1/4 turns out then adjust them either direction from there until you get the smoothest idle from each carb
    • RanMan
      • Apr 2006
      • 22
      • Glen Burnie, MD
      Sounds good brother. Two of them were around 1-1/4 and 1-3/8 so that may be the range to start with. OHHHHH boy!
      Thanks, Randy
      • randy
        • Dec 2003
        • 4521
        RanMan,
        Start with all the pilot screws 1-1/4 out.
        Do your synch with a mercury stick.
        After synch, with stick still attached, one carb at a time, rock the pilot screw in then out to attain the highest possible vacuum reading on that carb
        Move to the next carb, do all four
        Re-synch.
        You should then have the smoothest engine your side of the Mason-Dixon!
          • 5062
          I am no professional mechanic, but did you mean to say, "screw in then out to attain the highest possible rpm"?
          • randy
            • Dec 2003
            • 4521
            Skids,
            Either way the result will be the same, but it's easier to see the change on the stick than it is to see on the tach
