transmission help
  • Filter
  • transmission help
    i busted a shifting fork probley due to the counter shaft bolt laying in the cluch case, any way i fixed the fork but when i have it on the bench it wont go thru the gears right and dont want to put the motor back in if its not right. so can someone tell is it not going thru the gears because i have it upside down on the bench or did i do somthing wrong? I would be thankfull for any help out there.
    nytesurfer
    82 xj1100
    80 xs1100 special
    83 xs650 Sold
    84 fj600 Sold
    70 BSA chopper (old school) Sold
    Down to my two BEST
  • #2
    Do you have a service manual for XJ or XS11? There is an alignment process for the shifting lever/pawl with the shift drum. If you do a search for Shifter alignment or such, you should find threads with photos explaining this process!
    Also, the gears and shift drum don't like to move/work very well with the engine still, so pull the plugs, and then put a wrench on the timing cover plate, and rotate the engine clockwise while actuating the shift lever, and then you can better tell how and if the shifting will work!
    • #3
      no i dont have one if you have some info please fell free to send it to me nytesurfer@nytesurfing.com been doing search not finding much that helps but finding alot of good info in gen.
      nytesurfer
      82 xj1100
      80 xs1100 special
      83 xs650 Sold
      84 fj600 Sold
      Down to my two BEST
      • #4
        i think i got it done thanks for all the help will find out tomorrow agin thanks for being here
        nytesurfer
        82 xj1100
        80 xs1100 special
        83 xs650 Sold
        84 fj600 Sold
        Down to my two BEST
