Tacho Jumping
  • OzzieinXS
    • Apr 2006
    • 19
    • Australia Bonnie Doon Victoria
    Tacho Jumping
    My Tacho needle jumps around a bit,(internitantly) had it sycronised and a new needle fitted and still doing it. Any suggestons ?
    "A little bit of pain never hurt anyone" !
    78E
    Hey Ozzie,
    Check your connections for your charging system, the plugs with the 3 white wires for the Alternator. The tach get's its signal from there. You may need to clean them. Check to make sure you are charging properly! Could be an indication of a soon to fail system, usually the Reg/Rect!
    • AKMac
      • Sep 2005
      • 141
      • Utah
      Wait, is it the needle bouncing from 0k, or is it just shifting around a couple hundred RPM?
      I've also heard of a little ball bearing inside the tach housing that gets dirty and tends to make it bounce around just a little.
      1979 XS1100 Special (Chrome Queen)
      • randy
        • Dec 2003
        • 4521
        I've heard that, too. But I have an NOS tach that does the same thing, between 4500-6000 RPM. It's got just 1600 miles on it, used it first on W.V. trip. I agree with T.C., it's probably electrical in nature, loose or dirty something or other.
        When I get to it, I'll get to it.
        • OzzieinXS
          • Apr 2006
          • 19
          Thanks Guys
          I knew it ran electroniclly, but had no idea where to start looking. It seems fine in the lower rev range but the needle starts jumping as the revs increase. it dosnt seem to be from the road roughness. I'll give it a clean up and let you know if it helps.
          Thanks David
          • mastan
            • 349
            Where exactly are those 3 white wires located? My tach jumps too and it has been for the last year. I'd like to clear it up.
            Mark Stanton
            • Edisto
              • Apr 2006
              • 60
              • Roanoke, Va
              If I am not mistaken, the white wires are located behind the fuse panel. Remove the three screws that hold the fuse panel in place, and you should see them.
              1979 XS1100 F
              1980 XS1100 Special--Frankenstein
              1982 XJ1100 Maxium x 2
              1980 Honda CB 900
              1981 Honda CB 900
              1981 Honda CB650x2
              2003 Honda 1300 VTX Retro-sold
