hi all, so i removed the fairing and saddle bags from my 81 xs, now it wont start or turn over with starter button. is there a safety switch or wire that has to be connected as to start this without a headlite?
safety switch/wire
Check your fuses, bike should start and run without the headlight hooked up. Did you have the fuel tank off and disloge a wire from the tip over switch? Does any of the electrical work when you turn on the key? There is a 30amp main fuse under the left cover in a rubber fuse holder, all by itself. If this blows, you will have no power to anything. Don't trust a visual exam, either replace them with new or check for contiunity on all of them. Thisay sound dumb, is the "off" switch on the handlebar turned to "on". (Dont laugh, we all have done it
When a 10 isn't enough, get a 11. 80g Hardbagger -
thanks for the reply, but after checking all the fuses and wires i tracked the problem down to a broken kill switch, so i took it apart, and sort of fixed it. lol, wraped tape around it so it dont move. the inside is broke so i guess i need a new one. thxs.Comment
