FYI -ebay item #4644512967
Turbo XS on Ebay!
Looks great, and turbo too!
Wonder how much he's got the reserve set to.80 XS1100SG
81 XS400SH
Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
A Few Animations I've Made -
Home of ENIAC
Kinda like a MANIAC with 2 letters difference & a computer on boardComment
Just have to line your left pant leg with asbestos!
Steve80 XS1100G Standard - YammerHammer
73 Yamaha DT3 - DirtyHairy
62 Norton Atlas - AgileFragile (Dunstalled) waiting reassembly
Norton Electra - future restore
CZ 400 MX'er
68 Ducati Scrambler
RC Planes and HelisComment
Do you guys think I should buy that and swap the engine into my bike?
1979 XS1100 Special (Chrome Queen)Comment
a picture is worth xsive words...
yes you should and while your at it chrome everything and post your pictures in the pictures section of this forum to leave in prosterity for all to see...Originally posted by AKMac
btw how's it running, what did you do to jetting for those pipes?..."a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
78 yamaha rd 400Comment
Well I'm running a Mac 4-into-1 system on it now. It's running very, very strong. Now the only problem is that with the extra power, 2nd gear is starting to give me troubles
It feels like a chain is skipping. I'll be selling the ceramic coated Mac 4-into-2 on ebay soon.
Does anyone find it weird that the head is weeping oil on that bike? Wouldn't that mean that it's loosing boost? I've never heard about any XS having head gasket problems before. Also, I really hope that exhaust pipe has a heat shield.
I'm seriously considering buying this if the price stays reasonable. My goal is to have the sexiest, AND fastest XS1100 in existence.
Case Pressure and turbo 101
I’m not surprised at an oil leak from around the head on a turbocharged engine. If in fact it’s an oil leak it’s probably the result of the higher case pressures generated by the turbo. The breather system on this engine was not designed for it so it seems natural. I would think seals and oil leaks would be a perpetual problem with a machine like this. If the PVC system on a car engine isn’t up to spec they will also leak oil and blow seals. The way they seal a turbo on the turbine end is just with a simple rotating piston and slinger ring. The theory is the gas pressure in the turbine plenum is higher than in the oil pressure in the center housing of the turbo. That’s what really keeps the oil in the center housing and on the bearings. The piston ring or seal is really just there for low speed and static operation. The oil drain is about 3 to 4 times bigger in area than the oil pressure line. The intake side usually has a carbon seal of some kind but if it goes bad you will also get smoke at idle as the vacuum at idle can suck the oil out of the center housing and oil leaks at speed as the compressor is then putting out a higher pressure than what’s in the center housing and the crank case. Turbos are neat but they put a strain on every subsystem in the engine. Looks really cool though
wingnut
81 SH (Daily Ride)
81 XS 400
Thomas JeffersonComment
exhuastingly xsuastive
Originally posted by stevo
ak mac how much are you wantng for your mac 4 into 2 pipes you say ceramic coated ..what color are they .. what kind of mufflers...are they in good shape thanks stevo
check this out, i'm surprise you didn't follow this chromium genesis
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
The guy said that he had it up to 150 once...I understand that the turbo makes piles of power, but can the gearing and rear wheel even go that fast? He mentioned being 1000rpm over redline...is that enough to get to a buck and a half? That's nearly 4 bug..."Time is the greatest teacher; unfortunately, it kills all of its students."Comment
I donno, if some dudes on this site are reporting speeds up to 140, then 150 at 9.5k rpms doesn't sound wholly unreasonable...
...but I betcha he has an 18 inch rear wheel on there.Kristoffer
"Take apart yer carbs!"
1978 XS1100E - "The Maroon Baboon" (SOLD)
1979 XS1100 (3 of them) in the garage. Not deserving of names yet.Comment
