Fuel starvation?
  • Fuel starvation?
    I had De Ja Vu all over again with my bike shutting down on the road.
    I took it about 5 miles to a friends house with no problems. On the return trip it died on me about 1/10 mile after getting on the road. I primed the carbs for about 5 seconds and started her up again moving back to the "on" position. After about another .3 miles it died again, so this time I selected "pri", started up and hit the road. After about a mile I thought I could smell gas so I moved the petcocks back to "on" and managed to get home without it killing again.
    I know it's not the tank vent cap because I cleared that out when this first happened a couple weeks ago. Should I now check the Octopus and how is that done?
    80 XS11 SG
    79 XS750 SF
    74 KZ400
    78 KZ650
    78 KZ750
    It sounds as if you may have had a backfire at startup. That will sometimes blow the vacume tube off the fitting, usually at the carb. Just check that to begin with.
    Ray
      Ray,
      My tubes are/were alright. I found the vacuum test in the clymer manual and had to fight to get the tube off the intake boot in order to test the vacuum.
      I tried sucking on the vacuum tube with the forward fuel lines disconnected from the petcocks which were in the "ON" position. On 1 out of 5 tries I was able to get a little fuel to come out and I was sucking hard.
      80 XS11 SG
      79 XS750 SF
      74 KZ400
      78 KZ650
      78 KZ750
        Funky stuff happening
        In anticipation of pulling off the octo I had taken off the tank. I got to thinking that maybe I didn't have enough gas in the tank when I did the vacuum test so I put the tank back on, hooked up the two rear vac lines running to the octo and put more gas in the tank.
        When I switched the petcock to "on" fuel poured out both lines that would normally be attached to the forward fitting on the petcock. The vacuum line to the #2 intake boot was still unattached.
        Am I having petcock problems and octopus problems at the same time?
        80 XS11 SG
        79 XS750 SF
        74 KZ400
        78 KZ650
        78 KZ750
          You could have an "all at once" moment.
          Do a search on the octopus, and you will find the links on how to bypass the complete mess. As I have two STANDARDS, I don't deal with the octo. I do know that yuo may have some "junk" that is blocking the octo, and maybe it has killed the rubber seal in the petcocks.
          Just an ed-u-kated guess from an en-gi-neer.
          Ray
            Thanks Ray,
            I would like to save the octo if possible. I have taken the 4 screws out but not sure if I should just "pull" all the pieces apart. Don't want to break anything if possible.
            80 XS11 SG
            79 XS750 SF
            74 KZ400
            78 KZ650
            78 KZ750
              There is another thread with an answer. here is a clip:
              ps the part # was KL185100 from oldbikebarn.com for my bike. it comes with all of the gaskets for both petcocks and the vaccumn diaphram to rebuild that octapus thing for $32.
              That shoud help out, with a COMPLETE cleaning, you should be ready for a few more years.
              Ray
                Hey thanks Ray. I think I'm going to try cleaning it and if that doesn't work then I will order those parts.
                Question is: can I just pull the pieces apart after I took out the screws?
                80 XS11 SG
                79 XS750 SF
                74 KZ400
                78 KZ650
                78 KZ750
                  Yes, it should come apart. Be CAREFUL, as the rubber diaphram is old, and it WILL TEAR easily. If you stick a small phillips driver into one of the screw holes, just into the first part, and then pry, you should be able to seperate the parts without doing much damage.
                  Check the TINY vent hole on the back side of the diaphram. If it's plugged, the diaphram will not operate like it should. You may have no fuel, or always on fuel.
                  Ray
                    I can see all the separate pieces but everything is still attached by the "something" in the center. You are saying I can just pull it apart but do it gently?
                    80 XS11 SG
                    79 XS750 SF
                    74 KZ400
                    78 KZ650
                    78 KZ750
                      You should be able to seperate all the metal pieces, with a plastic piece in the center. The rubber diaphram will try to stick to one side.Judt be carefull, as without the kit, if the diaphram tears, your out of riding.
                      Ray
                        Membrane's were stuck
                        I found a thread that mentioned the membranes on either side of the plastic piece. I had to use a razor knife and WD40 to separate the membranes from the metal before I could pull them apart.
                        I didn't find anything unusual but cleaned as much as possible. The vent hole was fine however it appears that over time the membrane has been sucked slightly into the vent canal. Not sure if that's a problem. Anyhow I have put it all back together and will test it out tomorrow.
                        80 XS11 SG
                        79 XS750 SF
                        74 KZ400
                        78 KZ650
                        78 KZ750
                        • #13
                          Petcock leaks in "Off" position
                          With my tank sitting on the garage floor and petcock set to off it is slowly leaking gas. When the tank is on the bike I have not seen any leakage. Am I going to need a rebuild kit for the petcock?
                          80 XS11 SG
                          79 XS750 SF
                          74 KZ400
                          78 KZ650
                          78 KZ750
                          • #14
                            Yes, you're probably going to need a rewbuild kit for the petcock. However, before you do that, you could try flipping the rubber gasket over, and gently polishing the flat furface on the inner part of the handle that contacts this gasket. The gasket has a number of holes in it, and each one has a small lip. The lips get worn off from the valve moving back and forth as you operate it. Polishing the face of the valve helps ensure is is smooth enough not to grind off the lips around the holes. Flipping the gasket over brings the unworn lips from the other gasket face into use. Sounds a bit odd to read about it, but it will make sense once you open it up and have a look.
                            Ken Talbot
                            • #15
                              Ken, thanks for the tip but didn't work for me .
                              I did as you said and after reassembling the petcocks gas began to pour out even faster than before.
                              I got on Bike Bandit and ordered the rebuild parts today. BTW, it was alot cheaper than buying the rebuild kit from Old Bike Barn
                              80 XS11 SG
                              79 XS750 SF
                              74 KZ400
                              78 KZ650
                              78 KZ750
