My 81 XS1100H just doesn't want to start when it's been sitting for a few days. I'm going to burn out the starter at this rate.
Once it starts is fine I can restart with no problem. The idle is a bit high at 1700. I'm ordered a carb rebuild kit.
Am I on the right track?
Could it be the innition coil?
Some recommend a sigle piece of brass wire. Mine was clogged pretty good, and it took a sewing needle to do the trick. Just be careful. It wouldn't hurt to clean everything else while you're there. Just follow the tech tips to the left. After you're done, follow up with a carb synch. I don't think you'll need the rebuild kit, but I am sure not the carb guru in here (Or any other one to be exact!), this is just a problem I had in the past myself.
