ignition key
  • audijunky
    • Apr 2006
    • 707
    • VA
    ignition key
    I ll make this short and sweet. I have a 78 xs standard and was wondering how many positions the key can be put into. Right now I can only turn it one position. I insert the key and it turns one position to the right. Is this right?
    79 XS1100 modified standard
    straight pipe 4-2 exhaust
    Owned 83 Honda V65 Magna
    Owned 02 Vstar 650 classic
    owned 85 Honda Shadow VT 700C
    That sounds correct. One turn to the right, and with the handlebars all the way left or rightkey should turn to the left two stops. First stop is fork lock, second is fork lock with parking lights on.
    Sometimes you have to push down before trying to turn the key
    Ray
    • 81XS1100-2006
      • Feb 2006
      • 105
      • Minneapolis, MN
      FYI I've recently replaced my ignition switch, it seems to only be a two position, on/off.
      On top of that, it seems to be wired wrong, none of my lights work now.... (!)
      My thread My 81 XS Project has at least one entry on it.....
      81 Standard "Babe the Blue"
      sticky side down!
      • Pat Kelly
        • 3046
        • Golden Valley, AZ
        To turn it to the left (lock and parking light) you hat to turn the handlebars full lock either way, push in on the key switch, let it raise back up, then turn the key to the left.
        Pat Kelly
        <p-lkelly@sbcglobal.net>
        1978 XS1100E (The Force)
        1980 XS1100LG (The Dark Side)
        1999 Suburban (The Ship)
        1994 Dodge Spirit (Son #1)
        1968 F100 (Valentine)
        • audijunky
          • Apr 2006
          • 707
          • VA
          Thanks for the speedy reply fellas, I didnt think it was a problem just wanted to make sure.
