My 'F' has always been very easy to start and smooth idler. After a long ride, that all changed. It was a real pain to start and ran rough until warmed up. It got so bad, I would wear the battery down, cranking,
I did the carb tear down (a couple of time), but nothing seemed to help. In the mean time all the cranking took the battery out. It would no longer take a charge.
With a big ride coming up, I desided to take another stab at the carbs. Before I could do anything I had to pick up a new battery. Installed the new battery and Surprise! the problem was gone.
The whole time I was fussing with carbs, a bad battery was the problem. In hind sight it makes sense. The charging system does not start putting out until around 2k RPM. Until, then the battery has to be able to support the motors electronics.
A bad battery will drive you nut!
