Hi yall. i have decided on the paint scheme for my project bike. The Yamaha logo on tank will be in the way. Is it hard to remove ? is it just glued on?
yamaha tank logo emoval
tom macarthur
989 906 0443
photos click below
http://www.myspace.com/yadzillaTags: None -
Tom, I see by your profile that you have a 78E. Your emblem should be screwed on, unless PO used double-backed tape?
OR, the European paint schemes used a decal. Do you have a raised plastic logo or a decal?
This is what the correct 78E tank should look like after the emblem is removed. You can see the bracket and the 'dent'.
logo removal
looks like i have some fill in to do. Thank you alltom macarthur
989 906 0443
photos click below
http://www.myspace.com/yadzillaComment
you might want to get it poped out or have somebody weld a piece of metal over the dent and then get it flat then fill with the bondo because i talked to my bro about doing mine and he said it is better to just buy new emblems in my case because if he just filled it up with kitty hair and bondo it would just crack and break out from the viberation
my brother is a body man and he is doing all the work on my bike as far as painting goes but he is a good machanic too79 yamaha xs1100f standard
best 1/4 mile 13.282@99.40Comment
