what is the role of varying tire pressures
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    i'm light and want to optimize, i rode my f with unknowingly, 25lbs fronts on dunlop k291's and 30lbs on the k491 elites in the rear, and they rode great!
    when i upped it to 36 and 40 respectivley, they seemed a bit choppy, do i really need high pressures for going under 100 mph's?
    any help from anyone with a clue is appreciated!!
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
  • 81xsproject
    • 3185
    • Fortuna, CA
    I like the rubber on the road; the more the better. i too am pretty light @ 150. So, I keep mine just high enough that road imperfection (grooves, seems, crack-fills) don't affect me. When they are too low, I can feel them pull my bike this way and that. Just go with what feels right
    '81 XS1100 SH
    Sep. 12th 2015
    RIP
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      do you have a "rule of thumb" that you have developed, i.e. minimum, heat and mileage considerations?
      btw.... thanks i need this!
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • 81xsproject
        • 3185
        • Fortuna, CA
        I wanna say they are both in the mid-upper twenties, but really not sure. I am sure that one of the guru's will chime in and slap my ignorant OPINION in the back of its stupid head Were you feeling the road pulling the bike around at the lower pressures? My tires seem to be wearing okay for Kenda Crappo's. It is tough being a little-guy around THIS croud
        '81 XS1100 SH
        Sep. 12th 2015
        RIP
        • mason79
          • Mar 2006
          • 1359
          • los angeles, ca
          with my lousy riding i feel the road pulling me all the time regardless, your opinion matters to me, i'm 5' 7" 136lbs, and i guess i gained a pound over the weekend
          hmmm.. mid to high twenties, both the same?
          and thanks for the feedback it really helps!!
          History
          85 Yamaha FJ 1100
          79 yamaha xs1100f
          03 honda cbr 600 f4
          91 yamaha fzr 600
          84 yamaha fj 1100
          82 yamaha seca 750
          87 yamaha fazer
          86 yamaha maxim x
          82 yamaha vision
          78 yamaha rd 400
            • 5069
            Oh no...you just lost all credibility! ;-)
            • Just In Case
              • Apr 2006
              • 79
              • Auckland, New Zealand
              Hi. My XS1100E Yamaha Manual says:
              [CODE] Front Rear
              Upto 90kg 26 28
              90kg to 153kg 28 36
              153kg to 217kg 28 40
              High Speed 36 40
              So for us lighter guys, we can get away with a lot less pressure in the rear. No idea how fast high speed is though.
              David
              XS1100G (3X1 000274) "Torquey"
              You can think of a lightning bolt as essentially a really really big bug zapper. Unfortunatey, we're the bugs.
              • Just In Case
                • Apr 2006
                • 79
                Sorry about the mess in my coding, I tried to edit it but my editing time expired before I got everything looking pretty
                • randy
                  • Dec 2003
                  • 4521
                  I don't know, I just read the info stamped on the tire and go with that. Remember, the specs for our bikes were written 25-30 yrs ago, when tires were nothing like they are today.
                  I say go with the tire mfg's recommendations.
                  • Just In Case
                    • Apr 2006
                    • 79
                    Good point, though I've only ever seen max load/ pressure info on the side walls, so you might want to check the manufacturers website. But you'd need to know the weight on each axle to make a safe choice. Perhaps put the bathroom scales under each wheel while sitting on the bike (if you're allowed to, of course) Actually the scales might not go high enough for the XS???? Hmmm, time to think up a lever/ spring scale setup
                    • GNEPIG
                      • Apr 2005
                      • 1657
                      • fl
                      .. i dont know if this is the same or not, but i base my tire pressures off of the specs of a new model bike that i service/repair where i work. one that uses the same tire sizes and weighs about the same as our bikes. i even use the same tires as one of these models
                      the 130/90/16 rear set at 36 psi
                      the 100/90/19 front set at 32 psi
                      i have gone up and down with these pressures on my bike, but noticed that these numbers seem to give me the best feel for the road on my 79 Special
                      .. hope this helps
                      • prometheus578
                        XS-XJ Super Guru (RESIGNED)
                        • Aug 2004
                        • 4012
                        • Olympia , Wa.
                        "I'm getting "tired" of this"
                        Does one set the pressure low as the bike maker wants so that you get a comfy ride and like your bike, or to the tire makers pressure so that they'll last longer? Yes, there are a lot of other variables, such as speed, load, type of bike, and how one plans to ride.
                        Worked at one shop where the rule was: rear tire: 4 lbs less than maximum, front tire 10% less than that.
                        Current shop says: 36lbs rear, 34lbs front. (race bikes 34 and 32) depends how much grip they want, not being overly concerned with wear characteristics.
                        Big bikes, with big riders and bigger wives, I alway max out the rear, and do a few less than max on the front.
                        If an individual is sensitive enough to feel the difference, then he can damned well set them to anything he likes.
                        Just In Case writes:
                        High Speed 36 40
                        rounder tire, less rolling resistance and less flexing, hence less heat build up. I would consider this for fast, highway cruisin', but would drop it down if planning on whippin' around curves and such, then wanting a little more flexing and a larger tire contact patch on the pavement.
                        Can't have it both ways.
                        I think anything in the 20's is too low.
                        I run 34 and 36 and am content.
                        • 81xsproject
                          • 3185
                          • Fortuna, CA
                          See, I told you they'd get on here and slap me around
                          '81 XS1100 SH
                          Sep. 12th 2015
                          RIP
                          • xs650mike
                            • 1286
                            • Lake County, California
                            I'm light (suited up 150 lbs.) but I like my tires on the hard side for more precise steering. Kenda cheapos? Tried Kenda tires twice, both were out of round. The only cheapos I really like are CS Barracudas.
                            Different tire brands and models like different pressures. I just got a free barely used Avon Venom X rear because my friend found the handling "evil" on his Harley. He was running Harley's recommended pressure which is for the OEM Dunlop. The Avon requires more pressure according to the manufacturer. I'm currently running 30 lbs front (Barracuda H) and 36 rear (Venom X). Traction is there. Did a lot of riding in the rain this winter with nary a slip. On dry pavement the bike will heel over until hard parts scrape with no problem. This combination of tires works well, a lot better than the Metzler ME33 front and Dunlop Elite II that I had before.
                            Shiny side up,
                            650 Mike
                            XS1100SF "Rusty", runs great, 96k miles
                            XS650SJ "The Black Bike", engine from XS650H with 750cc big bore kit, 30k miles
                            Life is not a journey to the grave with the intention of arriving safely in one pretty and well preserved piece, but to skid in broadside, thoroughly used up, worn out and defiantly shouting, "WOW, what a ride !" - [URL="http://www.flyingsnail.com/Sprung/index.html"]Sprung[/URL]
                            • mason79
                              • Mar 2006
                              • 1359
                              • los angeles, ca
                              Re: "I'm getting "tired" of this"
                              Just In Case writes: rounder tire, less rolling resistance and less flexing, hence less heat build up. I would consider this for fast, highway cruisin', but would drop it down if planning on whippin' around curves and such, then wanting a little more flexing and a larger tire contact patch on the pavement.
                              you see, and i almost was going with seat of the pants... thanks
                              hey xs650mike,
                              i don't know if i'm going to push the bike to a point of scraping(scaring myself without that) but what parts do hit when it does?
                              History
                              85 Yamaha FJ 1100
                              79 yamaha xs1100f
                              03 honda cbr 600 f4
                              91 yamaha fzr 600
                              84 yamaha fj 1100
                              82 yamaha seca 750
                              87 yamaha fazer
                              86 yamaha maxim x
                              82 yamaha vision
                              78 yamaha rd 400
