One last suggestion just to cover all the bases! You did back out the adjuster screw on the brake lever where it pushes on the MC piston? Haveing that adjusted to far in will not allow the piston to return far enough for fluid to enter the piston area and you'll get no pressure.
Perhaps try removing the lever and pushing the piston with a dowel or something.
Steve
Steve
