Engine Noise
  • eleven_special
    • Apr 2006
    • 19
    • Canada
    Engine Noise
    My 1981SH had the smootheset running engine ever for years then I shimmed the valves(a procedure I have done annually for years) and it picked up a loud ticking noise after it has heated up.Cold it is like it always was,after running for about 10 minutes it starts to tick.My auto mechanic thought it to be a pin hole in the inner lining of the original double walled exhaust pipes.However the tick seems to be coming from #4 exhaust.I am certain it is in the valve.Any ideas on how I queered it while shimming and ideas on the fix? ER Carpenter
  • eleven_special
    • Apr 2006
    • 19
    • Canada
    To add to my post about engine noise:-Correction :the tick is coming from #4 intake.LOL It's getting late.
    ER Carpenter
      • 5069
      ER Carpenter
      You do know about the suppliment pages for the later bikes at the end of the Clymers, right? 80 and 81s are supposed to have tighter shim clearances than 78 and 79s. (But I doubt that is the problem).
        • 5069
        Also, losing spark from the plug wire to ground can sound like ticking.
