Gents,
'79 XS1100 Special (Awesome Ride when its right!)
Recently returned from an 18 month Central American tour. Drained tank and carbs prior to departure and after starting the bike every time I returned home for a visit.
The bike would not start and stay idling without some thottle so I put in new (hotter) plugs. Bike started and idled nice. Took it out for a drive and found that in the high end it runs fine, but by the time I got back the bike ran rough at the lower RPM. Initially before I changed plugs the #1 and #2 cylinders pipes were cold.
--The new plugs for the #1 and # 2 cylinder after I coasted into the driveway were sooty and wet.
So the question: can this be a sync problem between banks of carbs- 1 and 2 running way too rich? Or, am I forced to clean the carbs? Or, is there something else that may be amiss?
Compression is OK.
Compression is OK.
Started thinking that with the bike running high RPM producing full electrical power then coasting into the driveway with a defaulting battery maybe that had something to do with it - it did.
