Eliminating the Octopus
  • Eliminating the Octopus
    The propper way would be to run both lines from the petcock, Y them together, and run it straight in to the carbs, same with the other side? Correct?
    80' Xs eleven special "The Tank"
    I used 2 brass T fittings so that both lines feed both pairs of carbs on the mongrel.
    I also put VW bug fuel filters in line to keep the crap out of the carbs.
    Geezer
      Didn't think about splitting like that to feed everything. Kinda a redundant backup...I like that idea though. Just wanted to make sure I was setting it up right. Oh ya...Inline filters from the yam dealer...10 bucks apiece. Filters from Napa...1.99 ya price goudging I would say. Thanks Geezer!!!
        I'm an old, cheap SOB... There's no good reason to pay too much.
        Geezer
          I capped-off the front outlets (prime) on the petcocks and like geezer ran both rear outlets thru 2 T fittings to the carbs.
          Pat Kelly
          <p-lkelly@sbcglobal.net>
          1978 XS1100E (The Force)
          1980 XS1100LG (The Dark Side)
          1999 Suburban (The Ship)
          1994 Dodge Spirit (Son #1)
          1968 F100 (Valentine)
            I went low tech and easy, I capped off the prime taps by running a hose from one to the other... Cheap and easy...
            Geezer
              And here I figured you went all out... The dissapointment Geezer...the canadian igloo gods are looking down on you...
