what parts to switch from air to no air forks
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    i guess i'm going the progressive springs in the fork and don't want to deal with the air cap messiness on the bike with the fittings and dials, etc...
    i know i can keep them but looks are important to me,
    i would like to know for a 1979 standard, what pieces do i need to be able to convert it back, i saw a fork exploded view and there are lots of little pieces,
    i also have read the other years and models may have some adjustment, maybe this is not true
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    Air apparent!
    Hey Mason,
    There are lots of parts, but the only parts for the Air Forks are the Upper caps, and the Special Sliders. Air forks were only on the Specials, not the Standards! So...IF you have a 79 Standard, then how did you end up with Air Caps? Is your axle on the bottom of the fork tube lowers, or mounted on the leading edge a few inches above the bottom?
    Your bike may have been in a front ender, and someone may have put Special forks on a Standard??
    So...just swap out the air caps for Standard Caps!
    • Dennyz
      • 1151
      • Olympia, Washington
      I have seen air caps on Standard forks. Either they where aftermarket or somewhere, sometime the Standards came with them (maybe Euro).
      Anyway, all that is needed to covert back is a set of Standard caps.
      As T.C. wrote, make sure of the type of forks you actually have.
      FYI: Special and Standard fork caps are not interchangable (different threads).
      DZ
      Vyger, 'F'
      "The Special", 'SF'
      '08 FJR1300
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        hello topcat how are ya?
        well i neglected to say these were aftermarket, and are bulky items with balance hoses and a pressure gauge, hmmm....
        so if the po didn't tamper with the innards then lose a few pieces then my search for standard bolt begins! thanks again sir!
        I'm 5' 7" 135, do you think the progressives are going to be too stiff and that i'm better off leaving it the way it is and just service the forks with some 15wt oil?
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
        • Dennyz
          • 1151
          The advantage of the Progressive springs is that they provide a softer ride, yet get firmer as the forks compress. I found them to be a significant improvement over the sock spring for both ride and handling. Go with them!
          DZ
          Vyger, 'F'
          "The Special", 'SF'
          '08 FJR1300
            Denny,
            The problem he seemed to report in another thread was with what he called the REBOUND dampening being non-existent? The compression damping seems to be okay, but they extend too quickly or too easily!?
            Sounds like he may want to go up in fork oil viscosity? It will make it a tad more stiffer in the compression aspect as well, but should provide the increased valving/dampening affect he's looking for so that they don't extend quite so quickly!?
            I hope I interpreted his comments correctly? The different oil is a quick and relative cheaper experiment than new fork springs!
            • Dennyz
              • 1151
              There is an article somewhere about drilling out the damping piston to improve the damping action of the XS front fork, particularly in reference to rebound. I did the modification years ago when I installed my Progressive springs. I believe it to be a good modification.
              I think it may still be on the Yahoo site. I will look around for it.
              DZ
              Vyger, 'F'
              "The Special", 'SF'
              '08 FJR1300
              • Dennyz
                • 1151
                Here it is - good reading
                How to make the Yamaha XS11 Handle
                DZ
                Vyger, 'F'
                "The Special", 'SF'
                '08 FJR1300
                • Dennyz
                  • 1151
                  Well, that is not the article I was thining it was. I am still looking.
                  DZ
                  Vyger, 'F'
                  "The Special", 'SF'
                  '08 FJR1300
                    I know the airforks came standard on the 81 Venturer, as mine has them. They are individual valves with the chrome caps and are not the leading front axle forks. They came on Specials only(leading axle).
                    • mason79
                      • Mar 2006
                      • 1359
                      • los angeles, ca
                      yes, i'm trying to interpret what behavior my beast is manifesting with me and my riding.
                      and to address the negative aspect of those performances
                      topcat is correct in understanding my assessment, and factoring my weight; light, will i have a zone of tuneablity with progressive springs as maybe they are bias towards payload (read) full dress type bike like the XS vs. how far off am i actually, with the getup, i now possess. cost dependent.
                      btw, i'm try the picture thing andhope it shows up tada![IMG][/IMG]
                      you mean this right dennyz
                      History
                      85 Yamaha FJ 1100
                      79 yamaha xs1100f
                      03 honda cbr 600 f4
                      91 yamaha fzr 600
                      84 yamaha fj 1100
                      82 yamaha seca 750
                      87 yamaha fazer
                      86 yamaha maxim x
                      82 yamaha vision
                      78 yamaha rd 400
                        Picture looks good Mason.........nice example of a 79Standard!
                        • JWSanders
                          • 879
                          • White House, TN
                          Wow, nice looking bike! Very clean looking. Pretty sure those are standard forks since the clamps are on the ends.
                          80 XS1100SG
                          81 XS400SH
                          Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
                          A Few Animations I've Made
                          • mason79
                            • Mar 2006
                            • 1359
                            • los angeles, ca
                            thanks, pictures lie, not bad for a 27 year old, still gonna need your pipes, did you get the ones you bought from ebay?
                            History
                            85 Yamaha FJ 1100
                            79 yamaha xs1100f
                            03 honda cbr 600 f4
                            91 yamaha fzr 600
                            84 yamaha fj 1100
                            82 yamaha seca 750
                            87 yamaha fazer
                            86 yamaha maxim x
                            82 yamaha vision
                            78 yamaha rd 400
                            • GNEPIG
                              • Apr 2005
                              • 1657
                              • fl
                              Dennyz How to make the Yamaha XS11 Handle
                              .. this is the story i read in 03 on this web site, i followed the updated version and except for a good fork brace and drilling the damper rods, this is what i have done to my special and it handles real good. the steering feels way lighter than a 575 lb bike should.
                              .. the fork springs are 65 bucks and are way worth it
                              there will be far less front end dive and you will notice far less rebound action.. the original springs are 30 years old on a bike that weighs almost 600 lbs, the springs are sacked
