left turn signals don't work
  • mason79
    • Mar 2006
    • 1359
    • los angeles, ca
    the right side works perfect and when i wire the left side with the the right wires they work, the relay ticks away on the right and is dead on the left, could it be the relay or the turn switch? thanks
    History
    85 Yamaha FJ 1100
    79 yamaha xs1100f
    03 honda cbr 600 f4
    91 yamaha fzr 600
    84 yamaha fj 1100
    82 yamaha seca 750
    87 yamaha fazer
    86 yamaha maxim x
    82 yamaha vision
    78 yamaha rd 400
    • 7817
    Probably the switch. It's easy to fix, if you can solder. Pull the handle apart and CAREFULLY pull the insides apart. You should see the wires, and probably have one that has come off the copper piece it's supposed to be on.
    • mason79
      • Mar 2006
      • 1359
      • los angeles, ca
      thanks diverray,
      i didn't even need my vo meter, the little nugget popped off, and everything works when i touch it, thanks will solder later...
      History
      85 Yamaha FJ 1100
      79 yamaha xs1100f
      03 honda cbr 600 f4
      91 yamaha fzr 600
      84 yamaha fj 1100
      82 yamaha seca 750
      87 yamaha fazer
      86 yamaha maxim x
      82 yamaha vision
      78 yamaha rd 400
      • mason79
        • Mar 2006
        • 1359
        • los angeles, ca
        all done, almost forgot how everything went inside that switch pod, that much closer to a reliable bike! thanks again diverray and andreas for the blinker, by the way that rear fender was perfect!
        History
        85 Yamaha FJ 1100
        79 yamaha xs1100f
        03 honda cbr 600 f4
        91 yamaha fzr 600
        84 yamaha fj 1100
        82 yamaha seca 750
        87 yamaha fazer
        86 yamaha maxim x
        82 yamaha vision
        78 yamaha rd 400
