I got some progressive rear shocks off ebay. They are ablolutely amazing!!! I also got some progressive front springs. Should I still use air in the tubes? Would the air pressure balancing kits help?
air or no air w/ progressive front springs
'81 XS1100 SH
Sep. 12th 2015
RIPTags: None -
I don't use air in my XJ's forks since having the Progressive front springs installed in 2001. You still can, of course, but the pressure would be very low, a couple psi at best. Remember, air does not change the spring rate, it just determines the threshold force required to make the forks compress. If you use air, a balancing kit is the way to go, and use a low-pressure pump (bicycle pump) or, as I use on my rear air shocks, one of those CO2 inflation kits sold in bicycle shops and other accessory outlets to change fork pressure.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
"... life is just a honky-tonk show." Cherry Poppin' Daddy Strut -
Hey Jerry..........ridin' weather is great out there...(hint,hint).81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
does the air play a role in how fast the fork overcome rebound damping? oh air does not compress...air does not change the spring rate, it just determines the threshold force required to make the forks compress.
or is it more like preload?"a good man knows his limitations" dirty harry
History
85 Yamaha FJ 1100
79 yamaha xs1100f
03 honda cbr 600 f4
91 yamaha fzr 600
84 yamaha fj 1100
82 yamaha seca 750
87 yamaha fazer
86 yamaha maxim x
82 yamaha vision
78 yamaha rd 400Comment
Air pressure is Preload. Rebound damping is a function of the fork oil being forced though drilled passeges in a valve in the fork leg. Some folks try different weights of oil to get the "feel" they want, 10 wt is standard but you can get lighter (7.5 wt) and heavier (15 wt) oils.
Suggest you try the Progressive springs first, get the correct pre-load (about 1/4 to 1/3 of the total suspension travel with you on the bike, may need a helper for that) and see how the springs work for you.
There is a tech tip about improving the XS / XJ handling. It is getting a bit out of date now, but still some good pointers:
Improving your XS/XJ handlingJerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
"... life is just a honky-tonk show." Cherry Poppin' Daddy StrutComment
