Cable lubing
  • AKMac
    • Sep 2005
    • 141
    • Utah
    Cable lubing
    Hey guys, my clutch cable seems to be a little stiff. I was just wondering if anyone has any good tips on how to clean and lube it properly.
    1979 XS1100 Special (Chrome Queen)
  • wingnut
    • 695
    • NC
    The hard way
    I had the same problem. I took a business card rapped (making a funnel shape) it around the handle end of the cable and rapped it with magic tape. I discomfited the lower end and filled the little funnel up with MMO. Let it drain and refilled it till I got MMO out of the bottom end. Blew it out with air as best I could and it’s as smooth as silk now. Or you could go to parts and more and buy the cable lube adapter.
    wingnut
    81 SH (Daily Ride)
    81 XS 400
    Thomas Jefferson
    • prometheus578
      XS-XJ Super Guru (RESIGNED)
      • Aug 2004
      • 4012
      • Olympia , Wa.
      "I can't adapt to the cable lube adaptor
      Have two o' dem... have only worked properly on about three cables for me. I use the funnel method. But don't try to be smart and make a funnel out of duct tape. The lube you use has a tendancy to dissolve the adhesive and carry that gunk down into the cable. Then your cables will really stick.
      • mro
        • 4276
        • Hayward, California
        I stick one end thru bottom of plastic bag, electric tape wrapped on bag to about one inch below bag and then back up. Hang up over night. Place can under other cable end to catch dribbles.
        mro
        • AKMac
          • Sep 2005
          • 141
          • Utah
          So what are you guys using for cable lube?
          • wingnut
            • 695
            • NC
            Magic Juice
            MMO= Marvel Mystery Oil, available at AutoZone, Advance, Wal-Mart ECT
            wingnut
            81 SH (Daily Ride)
            81 XS 400
            Thomas Jefferson
            • prometheus578
              • Aug 2004
              • 4012
              • Olympia , Wa.
              Some silicone cable lube stuff from work. Don't use WD40, as it evaporates too quickly, leaving you dry, again. Use it to break up rust and free the cable, but then run something else down it.
              • charles
                • Jan 2006
                • 22
                • north platte ne
                oil coolers
                i have a question is it an advantage to running oil coolers on xs`s i have a cooler to put on my xs but not sure if it is an advantage or not and is that metal tube that runs from the top of the head to the top of the crank case is where i splice to hook it up to the cooler .......can anyone answer this question for me
                **1980 xs1100 special **
                • pggg
                  • 1609
                  • NZ
                  Chaz, good to have in a hot country but not a big deal, but the cooler plumbs to an adapter plate between the engine and the oil filter, not that rear metal oil line.
                  • charles
                    • Jan 2006
                    • 22
                    • north platte ne
                    ok is there a special plate i need to buy or is it already on the bike or is there a web site to check out about this
                    • xssiveone
                      • 766
                      • Windsor,Ontario,Canada
                      There is a special adapter plate that you need. It goes on first, with a special bolt, then the oil filter housing goes on. There are 2 fittings on it to connect each side of the oil cooler, which normally mounts to the 2 threaded holes near the top of the front frame tubes.
                      The odds of getting the adapter plate from a dealer are extremely remote. You might get it from a motorcycle wrecking yard, but more likely Ebay. They come up from time to time.
                      Brian
                      remembering the same thing!
                      • charles
                        • Jan 2006
                        • 22
                        • north platte ne
                        ok cool thanks ill see what i can find out
                        • Geezer
                          • May 2003
                          • 2985
                          • Willamina, Oregon 97229
                          I've been using the plastic bag method to lube cables for years. I use either whatever oil is left over from the oil change or automatic tranny fluid.
                          The clutch cable on the Mongrel was so full of dirt, 24 hours later no oil was making it through. It was too stiff to work up and down so I chucked up the clutch end of the cable in a drill motor and spun it and worked it up and down in the housing. I figured I had nothing to loose since the cable wasn’t usable as it was. Anyway after a few seconds of spinning it with the drill, the dirt started to flush out and I’ve been using that cable for the past couple years.
                          BTW, I use ATF to lube my guns too and as thread cutting oil. It's good stuff and cheap...
                          Geezer
                          • xssiveone
                            • 766
                            I just checked with a friend of mine today and he has one left over from his XS. Adapter plate, special bolt, cooling rad and hoses. He's asking $60 for it, but is open to offers.
                            Brian
                            Brian
