* I have pulled on the pickup wires while it was idling and it didn't flinch. I think I will try again to be sure. I actually had a repaired spare set with me on the trip. The spare set is from an SF and has different pickup wire routing on
the mounting plate...and it requires timing adjustment. I might have tried swapping them if I was dead in the water with nothing to lose.
* No added fuel filters, just the OEM locations (petcocks and carb needle screens).
* I thought about the "lazy susan" spark advance getting stuck, but I couldn't get to it easily during the trip.. I agree I should check it.
* I did think to pop the gas cap, even though the symptoms don't match this cause. It didn't make any difference to leave the cap loose.
* Petcocks have been replaced by an aftermarker manual ON/OFF style. I have the same ones on a few of my bikes.
* Vapor lock is an interesting thought. None of my other bikes have this problem, but I should look at the fuel line routing and see if there anything prone to heat.
__________________________________________________ __
It took a lot of effort to make the trip report, and I didn't have a chance to mention some important information about the history of trouble. When I first got this bike back on the road around 2019/2020, It had an incident where the #3 float stuck while I just riding along....and the airbox filled with gas the carbs flooded and it stopped while I was riding.
A few weeks later, it died as I was leaving church. It went a few hundred yards, and just chugged and died. I was able to restart it and rode home normally.
Then I rode the bike for 5 years with no problems.
Earlier this season, It died after church...just like before. I went a few hundred feet and it refused to accellerate past idle and then died. I started it again and rode home normally. I kept wondering if I didn't let it warm up enough.
Then It flooded and leaked gas at the gas station a week later. I knew that was a stuck float. I just started it and it jiggled back to normal.
Then the next time I went to ride, it leaked gas as soon as I turned on the petcocks. I knew that was the last straw, so I pulled the carbs and loved the floats and float pins. I ran a drill bit though the floats, rotating it by hand and pushing it in and out. I didn't have a drill to match the diameter inside the float, so I used the next smaller bit that I had. I polished the float pins with very fine sandpaper (maybe 1000#). All of the gaskets I had on hand protruded out into fload bowl area, so I bought new gaskets from MikesXS that looked like they didn't hang out and rub the float. That doesn't guarantee the gaskets might be a problem though.
BTW, during my rip last week, there was one incident where I stopped for gas and the gas pump refused my credit card. I strarted to go inside to pay, but saw that wasn't going to be convenient, so I decided to leave. I found I had a stuck float and the airbox was flooded. I was able to crank @ WOT and get back on the road.
So, I have history of float problems that I tried to fix a few weeks ago. Some of the symptoms on my trip are consistent with sticky floats, but some of the symptoms seem like there could be something else wrong.
Sorry I didn't share all this yesterday.I really appreciate hearing what others think.
So far, my homework assignments are:
(1) Check the "lazy susan" spark advance mechanism and be sure it's free.
(2) Do something drastic about float sticking - maybe buy a different set of floats and float pins. Run an exacto knife over the gaskets on the inside of the float bowls.
(3) Pull on the pickup wires with the bike running - again.
I'm listening to other thoughts and will add more to my homework if the shoe fits.
The good news is that validation testing will require another trip up north.
I really have an appreciation for the Venturer after this trip. It always seemed heavy and clunky for zipping around the local area. But out on the road, it is sooo ideal. I didn't even mind travelling on the slab with it. It buzzes along at 75-80 MPH so smoothly and comfortably. It carries a tlot of cargo. After riding it 900 miles, the weight seemed normal. I can't wait to get back on the road with my Venturer. BTW, everyone notices it and remarks how nice it is.
Its like going back in time,,,,great old bike,,,unreal scenery and serene,,,,THAT is a beautiful Venturer Mike,,,,,should outlast all of us. I have a beater Venturer and its still ticking at 150k plus,,,,it wont die, must be a Yamaha. Anyway,,nice pics, nice trip,,,gives all of us xs owners the desire to do those kind of trips and remember how great these bikes really are when running right..............Mike in San Diego and Pa.
Leave a comment:
