My winter trip
    My winter trip
    I left out this morning for my winter trip I’ve been mentioning. When I left, it was 29 degrees. I rode for a while until the sun started coming up good and got the obligatory starting out shot. For some reason, I thought I needed to bring enough clothes to where I won’t have to wash anything for two weeks. Hmmm.. Two week old dirty socks and underwear. The wife may not be so happy when I get home after all? Lol. I also have enough tools to pull a motor and split the cases if necessary, rain gear, and the laptop here.
    In this next pic… I have made it to central Texas. Central Texas is a blast to ride… here you have a mountain.
    And here is their cash crop…. Prickly Pear Cactus and Mesquite trees
    And here is their twisties! It consists of hitting the off ramp.. then back onto the freeway. You actually get to turn just a bit!
    I was headed to a guy’s place that I have been chatting with for a few months. He bought an old Atlas nuclear missile silo back in 1997 and has been working on making a home out of it. Some of you may find this next part boring, but I was really interested in this. I remember reading about the Cuban missile crisis in 1962 and how close we came to nuclear war.
    The silo I visited is just one of the original 72 that were around the Abilene Texas area. It was being hurriedly built and was finished the same year of the Cuban Missile Crisis.. 1962. A lot of people crawled in and sprayed graffiti over the years. This had to have been a daunting task. They had to climb in through the exhaust vents down into this silo where there was absolutely no light, and climb and hang on rusty metal to spray paint their message and names on the walls. One I saw was way back in a corner over that seemed to be more dangerous than most said, “Huge balls, little brain.” Lol.
    So, I turned off of I-20 and headed south. I stopped to call Bruce and tell him I was getting close. As I sat there, I thought… Man, I wonder if nuclear missiles actually came right down the road I’m on. It didn’t take long to answer that question rather blatantly.
    I turned off the highway to this non intimidating gate, which is the actual original entrance.
    A little ways in, and I see another gate coming up.
    Yeah, this one meant a little more business.
    And here’s my tour guide, Bruce, awaiting me. You can see the silo door beginning to rise to the left of the flag.
    A little higher…. It took some effort. These doors weigh 74 tons each!
    And here you can see a few floors down into the silo. Don’t trip though… it’s 184 feet to the bottom!
    An old quonset hut to the side of the pad. To the very right of the pic, you see the entrance.
    You can’t really see it, but in the center at the very back of the pic under that tree, there is a concrete pad that held a telescoping radio tower that was 90 feet long when all the way up.
    Had to throw in another bike shot with the silo door all the way open.
    The entrance…
    I took a pic, but it didn’t turn out. You go in that door and down approximately 2 stories, then turn right, and you come to the first blast door. They made these angles at 90 degrees to reduce the blast force. These doors are several thousand pounds, but I can move them with one finger. They are pretty rare to still be existing. Very few left are still there let alone operational.
    Through that blast door and another 90 degrees to the right, is another one. I wish I had gotten a better pic of the latch. I don’t think a bank vault has anything on these doors.
    Through that blast door and down the steps is where he’s made his main living area. He’s removed a third blast door, so you can see right in.
    I felt bad taking pics of the guys house, but here’s a shot back into the kitchen. The main funnel-shaped column to the left you see supports the ceiling and goes to the floor 2 stories down. This level of the home as well as the one below it are free floating.. they are hanging from the ceiling. What this did, in the event of a close blast, it would shake the ground and walls, but the supported rooms would stay stationary. This level where the kitchen is used to be the crews quarters that had the showers and bathrooms. The level below this was the actual control room. This structure was actually separate from the missile silo.
    One of the hangers attached to the roof.
    To be continued...
    Over his kitchen area was the crew escape hatch. You were to pull the handle you see, and the door would swing down. This would let several tons of sand used as a blast shielding to pour in. You climbed up this sand pile to the ladder, and out to freedom. I just wonder what they thought would be left?
    Remember the second gate I went through? This is his window.. equipped with microphones. You can hear birds, wind, rain, etc.
    All around the whole room, there is a 6 inch metal lip with several inches separating the floor from the walls. The concrete walls at this level are 40 feet thick!
    And here’s down on the second floor where his gym and bathroom are, shooting up next to the column to the first floor.
    And this is the original sign from the 60’s… so he thought he’d stick a fire extinguisher there also.
    Back up to the first floor, we exited through where entered, but instead of going up the stairs, we went to the left and went down. The door you see here is a blast debris door. This is to help stop debris if the missile were to explode while in the silo. Apparently, this was a bit of a problem, and he rattled off at least 4 times that he knew of. There was a lot of hydraulic fluid around with a lot of liquid oxygen, and the two don’t play well together. Also, the actual shell of the missile is very thin and would crumple under it’s own weight. It was approximately the thickness of a dime. There had to be a positive pressure inside the hull of 5-6 psi at all times. If there ever got to be a drop in pressure, alarms would sound and they’d have to try to get to the nose of the missile and attach a hook and basically hang it until pressure could be restored.
    Through the debris door and heading towards the silo, you can see another blast door.
    And another after that.
    And out to the silo.
    And here’s a shot to the bottom. When he bought this there was over 60 feet of water covering several stories of the lower levels. The metal has been pretty rusted down there. It took him over three months to pump the water out. He said he occasinally drops a tool down there, and about once a year, he'll make a trip down there to gather them all up. lol.
    A tiny bit of the graffiti.
    The whole silo is supported on these giant springs on the sides. Each spring is 4-5 feet long.
    And they go down a ways...
    Some of the stainless steel lines for loading fuel onto the missile. From the time they got the order, it would take approximately 15 minutes to fuel, raise the missile to the surface, and fire it away. He said the manual for firing the missile was very complex, but when it got to the part that the missile was launched, the manual just ended. There were no instructions on what to do next.. lol. Wait a couple weeks before exiting, await further orders?? Nothing. Through several things they saw, these men realized they were just expendable.
    LOL.. This is a bad pic, but it’s to show how long people had been breaking in and climbing into the silo. This beer can is the old pull tab style.
    This is just part of one of the floors, and every single floor had been packed with electronic equipment. There was hardly room to walk between everything. Where the missile was, was separated from this by some aluminum foiled insulation. The missile was kept at 70 degrees, but this area was separate from that and was hot and noisy they say.
    Another shot of the ram. This thing is every bit of 20 feet long.
    He’s covered them to keep the water out, but this is the blast exhaust ports that the people would climb down into to get to the silo. Supposedly a pretty harrowing experience, but it seems many made the trip.
    Door closing…
    And all down…
    To be continued...
      Bruce was lucky enough to meet one of the guys that had worked on this site back in the day. He had some pics that he shared with him of the site in operation, of the particular missile that had been at this site and such, and he shared them with me.
      Ready to go….. Scary stuff.
      The control room.
      This was all supposed to be top secret, but the government thought it would be a good idea to show the people of Abilene what they were putting in the ground all around them. So, they brought an Atlas missile into downtown Abilene and set it up for them to see! Lol. Gee, that’s pretty secret!
      Here’s the missile as it was unloaded at the local Air Force Base from a C130. Not much room for error! I bet they got better fuel mileage on the way home!
      And here’s one of the construction phase. Notice the people standing on the area separate from the silo where his home now is.
      And here’s the missile as it turned off of I-20 onto the ICBM Highway.
      Finally, I said good bye and headed off into the sunset.
      I got into Big Spring Texas and grabbed a motel where I am now sitting typing this. Total miles for the day was just shy of 500 at 497. Tomorrow… headed to Carlsbad, New Mexico.
      • XSokieSPECIAL
        • Jun 2009
        • 1631
        • Tulsa, OK
        Hey Tod!,
        Great stuff man. Was wondering how you were doing.
        I've got 3 12 year old girls staying here wifh my daughter for her birthday/slumber party. They were up watching scary movies late and I guess they were too scared to turn off the lights and TV before they went to bed.
        I had to get up and turn everything off so I thought I would jump on here and see whats up.
        Glad I did!
        Good to see your having a good trip so far. Great pic of that central Texas mountain. I think I've seen it before. But then, if you've seen one you've seen them all. I gotta get me one of those missle silos.
        Looks like it's getting warmer as you head south. Hope it holds out when you cross the mountains in New Mexico.
        I know you'll stay in touch.
        Have a GREAT trip.
        Be safe brother!!!
          That is some cool stuff. I don't know why, but I much prefer the "private" historical stuff like this over the commercial "National Park" type stuff.
          I have been involved with some bank vaults before, and I think they may come close, but still second place to those blast doors!!
          • Ivan
            • Jul 2008
            • 2524
            • Hutchinson KS
            Cool stuff. That had to be kinda eerie standing in a place that could have started the apocalypse.
            Hope your trip is as good the rest of the way.
            Ich habe dich nicht gefragt.
            • 1st bike
              • Nov 2009
              • 258
              • indiana
              tod that was great! thanks for posting that, it was so cool to see! what a great trip this must be for you. that guy was really nice for letting you take pictures of his home, but what an awesome home! i can't imagine the feeling of that door closing though!
              thanks tod. travel safely.
              1980 XS 1100 Special (working to be my daily ride)
              • joceiphus
                Xsive
                • Oct 2009
                • 285
                • Tulsa
                That was very awesome! Thank you for the great pics.
                Joe
                Joe
                78XS1100
                • xs11jack
                  HALF GURU
                  • Nov 2002
                  • 606
                  • O'Fallon, Mo.
                  I agree with DGSER,
                  I like the private stuff too. In fact there are pieces of our military history that no one sees, and this is one of them. If your friend had not given you the opportunity to post the pictures, only a handful of people would ever see the "Silo Era." Thanks Tod.
                  Jack
                  J.D."Jack" Smith
                  1980G&S "Halfbreed"
                  1978E straight job
                  "We the people are the rightful masters of both congress and the courts, not to overthrow the constitution, but to overthrow the men who pervert the constitution." Abraham Lincoln
                  Life is like a coin, you can choose to spend it any way you wish, but you can only spend it once. Make your choices wisely.
                  • XS1100 Newbie
                    • Jun 2009
                    • 1106
                    • Battle Ground, Washington
                    I still remember having to dive under my desk at school during the air raid drills. We even got to go below the courthouse to see an air raid shelter. Little did they know at that time, but the air raid shelters were only death traps.
                    1980 XS1100LG Midnight
                    1991 Honda CBR1000F Hurricane
                    A cold beer and another one!
                      A new morning, and I’m sure the bike likes all my stuff off of it. It sure is better off the start… but soon it’s time to load it up like a mule again and head out.
                      Big Spring Texas has a nice feel to it.. a bit like home. Maybe it’s because there’s a big asylum there for the criminally insane? I think I sat next to an escapee at breakfast. That chick was a PSYCHO deluxe! I couldn't get my coffee chugged fast enough.
                      So I started out and looked up, and saw a guy changing out a window. I thought this would be a good job for Kat to get since she likes heights so much…
                      I headed out on the road. After a while, I started seeing lots of cotton fields.. as far as the eye can see…
                      And here is one of the bales after harvesting. No telling how many t-shirts that thing could make.
                      Ya know, I ragged a bit on Texas yesterday, but to be honest, at least they had a few scraggly trees to look at. Eastern New Mexico is not the most scenic byway I’ve ever ridden
                      So I pull into Carlsbad fairly early, find a motel to stash my stuff, then headed out to the Carlsbad Caverns. Still no fun roads… until you turn into the park, then the scenery changes completely.
                      I haven’t seen decent twisties in days, and you want me to take a corner at WHAT speed now that my bike is unladed?? Ummm.. yeah, ok. The pegs now have a couple new shiny spots on the bottoms.
                      To be continued...
                        So I arrive at the Carlsbad Caverns. A warning to folks riding there… You either have to leave your stuff on your bike, or carry it with you the whole time. There are no lockers available. I don’t like leaving my helmet and stuff in the parking lot, so I ended up lugging it along, but it ended up being a blessing in disguise. You can’t touch anything but the stainless steel railing. To get a decent shot, you have to set up the camera without a flash and let it just light gather for a while as it sits still. I would put the coat on the rail, then the helmet on the coat… then the camera on the helmet.
                        This is the pretty color you got if you used flash.
                        I was honestly not looking that forward to coming here. I’ve been to the Grand Canyon and was like.. “Yup, it’s a hole in the ground.” I was expecting to walk into a cave a hundred feet and take a few shots. WRONG!!! It was just $6 to get in for adults, and I was blown away. First, you get in an elevator that zips you down 750 feet into the ground. The park ranger is jabbering away, and you can see the wall of the elevator shaft flying by just inches away. Your ears will pop several times on the way down. After you get off the elevator, you just follow the footpaths around. I was astounded at the sheer size of everything. In some places, you had to almost duck to walk through, but others were 2-300 feet high to the ceiling, and many of the bigger rooms were hundreds of yards across. It is nearly a mile and a half walk to get around this cavern, and it’s just one of several! In many of these photos, if you look close, you can see people in the background to kind of show you the scale of things.
                        They even had some natural cave porn there!! And yes, the stains were there BEFORE I got there, thank you! Lol.
                        They had an exploration into the cave in 1924, and a guy left his ladder for others to use. Many people didn’t like the swaying of the ladder as they climbed down over 90 feet into the 2nd level. Look at those rungs! ??? Looks safe to me?? Lol.
                        This one looked like a sheet hanging out of the hole.
                        The sun was starting to go down, so I took a parting shot from the hill the caverns sit on.
                        Then I went back to town. Here in Carlsbad, they have a thing called Christmas on the Pecos. Basically, everyone along the Pecos River in town decks their yards up with Christmas lights. You pay $17.50 to hop on a pontoon boat for 50 minutes with a bunch of other people herded on like cattle, and they cruise up and back showing you the lights. Sounds cool enough.. only… I’m a cheapskate, and for me to pay nearly $20 to go on a pontoon boat for an hour, there better damn well be a fishing pole on the thing. So I went looking for this Christmas on the Pecos, and see if I could get a shot of any of the houses for nuttin’! I saw this fountain along the way.
                        This is where the pontoon boats launch from on the other side.
                        I found a dead end road and got this shot of part of the lights…
                        Then I saw this idiot’s place on the way back. There wasn’t a square foot of his yard not being used. They had a nativity scene, a working ferris wheel, a train going around, a teeter totter, and lights set to music.
                        Then it kinda hit me. On one hand, it’s been a few years since I’ve seen my parents and brother and his family. So I’m excited about that, but then… I’ve never been away from that gal I’ve got at home during Christmas since I was 17 and we were just dating. And I’ve never been away from the kids…
                        So… Tonight I’ll sit and drink a couple. Tomorrow, I don’t have many plans really. I have to go over a mountain pass in the morning.. hopefully some good views for pics.. then just ride. I only rode about 250 miles today.
                        • 4.0xj
                          • Dec 2009
                          • 12
                          Well if it starts to snow too bad remember, I do have a xj with 4 wheels and a heater you are welcome to anytime.
                          • Wildkat
                            XS Special Gurette
                            • Apr 2004
                            • 3416
                            • Location, Location
                            Most of them anyway...
                            lol
                            As much as it will suck being away from your wife and the kids... your Mom will have a memory that will be cherished for a lifetime...
                            Continue to enjoy your trip, have a great time... and as always... be safe...
                            (as you can anyway)
                            By the way, that window washing job? your riding partner and I have decided that is the absolute last job on earth we will ever get... unless they figure out a way to lower those windows to basement level...
                            lol
                            81 SH Something Special
                            79 SF MEAUQABEAUXS
                            81SH Nor'eas tah (Old Red)
                            80 LG Black Magic
                            78 E Standard Practice
                            James 3:17
                            “Alis Volat Propriis”
                            Yamaha XS 1100 Classic
                            For those on FB
                            • XSokieSPECIAL
                              • Jun 2009
                              • 1631
                              • Tulsa, OK
                              Man!
                              It looks like a great time.
                              I've always wanted to see the caverns. Been by there a time or two but circumstances wouldn't allow the stop.
                              Be real careful on those highways, I see there are lots of sharp curves.
                              Nevada is the same way. You can see the road 50 miles ahead of you......straight ahead of you.
                              Keep the pics coming man, they're great. And don't hang around those cotton fields too long, I've heard some of those cotton pickers are out of thier cotton pickin' minds.
                              Be safe bro' and be careful in the mountains.
