Por-15
  • Chuck38
    • Jul 2018
    • 3
    • Marietta ,GA
    Por-15
    Is this a good, bad or ugly gas tank cleaner/sealer?
    80 XS11
    • 8073
    I never tried it. I use the epoxy from Caswell. I've never heard of it failing when properly applied.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      coat or not
      Hey Marty,
      I had a problem with Caswell, probably me. I've seen Por-15 get all weird too, was not me someone else.
      The best way I've found Evaporust, eats the rust out. Once the tank is flushed, look inside (dental mirror). If no rust dry ASAP (compressor and blow gun) then final rinse with a couple bottles of yellow HEET and put into service ASAP.
      If you still want to coat before you put it into service, you have a nice clean surface and the best chance of a successful coating application.
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
