Standard Rings - cruzinimage_co
    • 1247
    • Peachtree City, Georgia.
    XS Folks,
    I recently purchased and installed new rings in one of my XS11's. I purchased these from e-bay seller "cruzinimage_co " of Chiba Japan. $42.95 plus $9.60 shipping.
    The quality of these rings is very good and what I believe would be comparable/equal to OEM. I do not BELIEVE OEM STD rings are available any longer from Yamaha. They are not available from Partzilla.
    The compression in this bike was soooo bad it wouldn't even start (60#).
    Rather than perform a re-bore with new pistons & rings and machine shop charges I installed these new STD rings. Combined with a minor FLEX hone job I got my compression to nearly OEM spec.
    The ring gaps were SLIGHTLY beyond spec (.008 - .016) at .022-.024 but well within the wear limit tolerance of .039.
    The bike started on the second revolution and it runs very good.
    I just purchased another set for another of my XS11's and they arrived in THREE DAYS! I don't know how the heck that happened but it was a pleasant surprise!!! Highly recommend this product and this seller.
    KURT
  • Prothec
    • Jul 2007
    • 587
    • Fort Myers, FL
    Thanks for the evaluation. Great to know there is someone out there making standard rings available at a reasonable price
    How long did the first set take to arrive? Debating whether to order a set for the future while they're available and so I won't need to wait on parts from Japan.
    Website/Blog
      • 1247
      Signature Required
      Prothec,
      The first set took ten(10) days to arrive.
      There is one little GLITCH with this seller or perhaps with customs? The packages required a signature. Since we're not normally home when the mail arrives I had to go over to the post office to get the first set. I sent a note to the seller to send the second set without a signature requirement but they came that way again.
      Luckily, the second set arrived on a Saturday and we were there to sign for them.
      I don't know if the signature was required by the seller or by customs? It may be that the seller has no option in the matter?
      KURT
        • 3932
        Hey Kurt-
        What size flex hone fid you use for honing your cylinders? Mike has me thinking about replacing my rings abd honing my cylinders (gotta replace the base gasket).
          Hey Kurt-
          I have a 73 mm flex hone that I used when I did my rings.
            • 2079
            Grit too!
            You need to consider the grit size too.
            I'll look tonight what size and grit I used.
            You are welcome to borrow it.
