Brake lines
  • Robsweetland
    • 73
    • Devon,uk
    Brake lines
    Just fitted a set of wezmoto lines, front and back for 80 GBP, easy fit, plug and play seem very good quality, need visor wipes now cus me eyeballs are popping out it's made that much of a difference, they are on ebay and are model specific, or you can customize.
    79SF
    xjr ohlins shocks, tarozzi forkbrace, bsa handlebars, bsm exhaust
  • Robsweetland
    • 73
    • Devon,uk
    These come as a kit with everything you need and all fittings are stainless
    79SF
      • 3180
      Stainless lines and more from XJBikes.com
      As some of you know I have been working with Len aka Chacal from XJ bikes to make a set of lines available for our XS11's. My part only consisted of starting the ball rolling, clocking and test fitting these lines. I did a seperate set for each of the models. So now we have lines for the Standard. Special and Midnight Specials. Incidentally, I have nothing to do with the pricing or profits from this endeavour.
      These lines come in original rubber and Stainless Steel with 4 colors available (Black, Clear, Bright Red and Bright Blue). All were fitted to original bikes with original bars. If you require custom length lines you will have to contact him yourself and see what can be done. There is however a single replacement line for the stock 3 piece rear lines on all models that has been fitted and is ready to go.
      There are whole myriad of other parts and pieces available through him as well and the easiest way to say what is all there is to ask you to read though the price list. I will say that it ranges from banjo bolts to Rotors, pads and much more.
      These are a quality set of DOT approved lines. When the final test fit lines arrived I could simply drop them into place with no hassles. This started Feb/2012 and finally came into being a week or so ago. It has been a long time in the making and I hope you all enjoy the results.
      As for the contact info:
      info@xj4ever.com
      will get you to Len who will be able to answer all your questions.
      The price list with all the available parts and pieces can be found at:
      http://xjbikes.com/Forums/viewtopic/t=40222.html
      I do hope you take a look and see for yourself what this link may be able to do for you and your ride.
