Snap Depth Gauge Digital Electronic Dial Indicator
    • 3956
    Decided to order the above for the purpose of measuring float height. When I decide to undertake that project, I will let you guys know if it performs any better than a standard digital caliper with the depth gauge on the bottom.
    • 8062
    Like this?
    I have one of these and it works very well. It has to rest on the lip of the carb body, so that space must be accounted for.
      • 3956
      Mmhmm. But, from my understanding (I could be wrong), you want the measurement point of reference to not be on that thin ridge, but the flat spot on either side of the ridge. In other words, the tip of my caliper should rest on thevflat spot of either side of the ridge. Correct? If not, then I've been measuring float height on all my bikes wrong, all these years.
        • 8062
        Yes, the flat under the ridge.
          • 3956
          Ohhhhh . . . I see what ur saying Marty. Your carb ruler is too wide to manipulate the flat area. So, you have to "account" for that with your's. Gotcha.
            • 8062
            It does read flat across the top of the float. That is its only real advantage.
              • 3956
              Yeah, but you have the flat plastic floats. Much easier for you.
