Inder sidecar
  • Crusty Snippets
    • Sep 2010
    • 428
    • Gabriola BC
    Inder sidecar
    Delivered to my dock this morning.
    There is some nice welding and some nice metal work.
    The following will not cause me to return the unit, but I will talk to the supplier and encourage them to tell the manufacturer some of their work needs improving.
    There is no spacer for the top shock bolt, has about 1/16 of play all around.
    The tyre would not hold air, tube has a three inch split.
    Axle dust cap would not fit over the washer that goes next to the bearing.
    Inner wheel bearing was too tight on the shaft due to paint on axle shaft and poor machining.
    Inner bearing was too loose in the wheel hub.
    Off the six frame clamps, one had a smaller hole for the same size bolt.
    Rear hatch ( boot ) lock not working after about six uses.
    Wheel hub between bearings had small metal pieces from machining.
    Only one bolt to secure back rest of seat, and foot step. Two are required for each.
    Windshield has a small crack staring from a mounting bolt.
    Tomorrow after fixing the tyre and tube I will attemp to bolt the rig to Yami.
    Unkle Crusty
  • dpotter58
    • Aug 2004
    • 1866
    • Southern Maryland
    Which one did you get?
    1980 LG
    1981 LH
    • Crusty Snippets
      • Sep 2010
      • 428
      • Gabriola BC
      Sidecar
      Sidecar is made by Inder Auto Industries, in Nangal India.
      A photo is at www.cozysidecar.ca products and is the Bemer model.
      We are slowly making progress figuring out the handling.
      The steering is much too heavy at the moment.
      Had too much lean in, fixed, too much toe in, fixed but went too far so had too much toe out, fixed. Now all I have is too heavy steering.
      Found sidecarclub.ca There are links to much theory which at the moment is disagreeing with my logic.
      Weight on the front increases heavy steering, my logic thinks moving the car back would help. But apparently moving the car forward helps. Must have to do with the placement of the sidecar wheel, rather than just mass.
      I will cut down the windshield as it is too high and has too much drag.
      Connecting the four links to the frame was an interesting exercise.
      Did it all on the dock, would have been better with a couple of small floor jacks.
      That's the sidecar news to date.
      Put about 70 miles on it today, was hard work, made changes at the ferry dock to adjust the bike lean.
      Unkle Crusty
      • jwhughes3
        • 2798
        • Home of the Alamo
        I think Fredintoon mentioned before this is one instance where you want to mix the forks and triple trees from standard and special to get what would be squirrley steering on the bike, but with a sidecar lightens steering.
        Dont ask me which with which. Ask fred.
        BTW car looks cool.
        John
        '81 XS1100H - "Enterprise"
        • slow mo
          • 858
          • ontario canada
          you need a Steering damper otherwise the xs11 with sidecar is UN ride able ,, just my 2 cents ride safe slow mo!!
          The Belfast Express {1980 xs11oo special/TC fuse box/mikes xs pods/bad boy horn!/mikes green coils/mac 4 into 2 exhaust/ standard bars/vetter fairing c/w ipod CD iphone am/fm radio/tkat fork brace ,,,tuned by tinman
          moemcnally@hotmail.com
          i AM THE KING OF NOTHING
          the people here are great , doesn't matter about the bike really/hamjam ////
          • Crusty Snippets
            • Sep 2010
            • 428
            • Gabriola BC
            Damper
            Hi Slow Mo.
            I will be going slow around corners, because if I go bit quick we go straight ahead. The steering is that heavy.
            Or the steering head angle is wrong.
            I will be moving the sidecar forward 2 1/2 inches for the next adjustment. That should give me some feedback as to balance.
            If you care to add an extra 98 cents worth I will listen. So far we have been 110 kph with no mayor drama. I have deliberately wiggled the bars to check what might happen.
            A steering damper can be added. My sidecar theory is very old and mostly limited to the race track. From that experience I determined they were slow on acceleration and breaking, but okay around the corners.
            This is the first time I have bolted one to a frame.
            It is currently serviceable but at a slow speed and there is much room for improvement.
            There is a Canadian Sidecar Club that has links to much imformation that I am studying.
            Unkle Crusty
            • slow mo
              • 858
              • ontario canada
              damper
              slow speed is where you will encounter steering head wobble ,,,,, a steering damper should be applied by a professional the is a lot of geometry going against you ride safe slow mo!!
              • slow mo
                • 858
                • ontario canada
                steering damper
                with my steering damper all turns are better if you send me your email addy i can send you pictures ride safe ,,slow,,mo!
                • Crusty Snippets
                  • Sep 2010
                  • 428
                  • Gabriola BC
                  address
                  email is unklecrusty@gmail.com
                  Unkle Crusty
                  • slow mo
                    • 858
                    • ontario canada
                    i will take some better pics tomorrow ride safe ,,slow mo!
                    • Whistlingman
                      • Mar 2014
                      • 2
                      • Fredericksburg, TX.
                      Side car
                      My XS11 came with a Velorex sidecar attached. I believe that the sidecar wheel axle is 10 inches in front of the back wheel axle. Have fun adjusting the lean and toe in! I do not experience have steering, have relocated the handlebar with a riser adjustment which improved the riding position. Be careful driving the thing, it does not handle like a 2wheeler at all, especially making right turns. I believe Cycle Gear has a book on the subject. Anyway, good luck and be safe!
                      80 G
                      • Crusty Snippets
                        • Sep 2010
                        • 428
                        • Gabriola BC
                        Inder
                        I found another XS11 with sidecar in Victoria. Have been chatting with owner. He says his is easy to steer, suggests my problem is with the camber of the wheel. His wheel is 16 inch and the car sits lower than mine with the 19 inch.
                        So next on my list will be to set the wheel at 90 degrees to the frame. He also said 3/4 to 1 1/2 inch toe in works. His bike is a Standard, but that should not make any difference. I also have new front forks for Yami that I will install soon.
                        Unkle Crusty
