This is just my opinion. When I first bought my bike, it would not shift properly. False netruals, missed shifts grinding gears, you name it - it did it. Switched to Bel-Ray oil for some time. Did see SOME improvement, but still had problems. Down side was 30 bucks for oil change. So, I switch to regular 20/50 weight car oil. seen some improvement but still had problems. Where I work we use a product called Lucas heavy duty oil stabilizer. Noticed a difference right away. Missed shifts and false nuetrals & gear grinding became almost non-existant. Changed the oil & used 20/50 weight motor oil with the Lucas oil stabilizer & had even better results. Now after 3 years & approximately 12,000 miles have had no tranny problems. Clutch doesn't seem to slip either. So in my opinion, this product DOES have it's benefits. I also use it in my middle gear drive & my final gear drive & has cut down on noise from BOTH dramatically. But once again, this is only my opinion & this my be only unique to MY situation. But I think that anyone who is having any similar problems might give this product a try & see what the results are for them. Will not fix any 1st or 2nd gear problems for sure. (First hand experience)
P.S.
Was told, when I first bought my bike, that I would have to have tranny rebuilt. Have NOT had tranny rebuilt & have 14,000 miles on THIS bike since I purchased it.
"Live to Ride - Ride to Live"
P.S.
I personnaly have not experienced any starter or clutch problems since i have used this product. when I bought my bike it had 14k of abuse on it.previous p.o. didn't believe in any kind of maintenance. on my first ride was hard to shift. always loud clunk when shifting.false nuetrals missed shifts engine was noisey. when it was time to change oil my cycle shop said to use bel-ray 20w50.this helped with shifting.after 3 oil changes this was getting exspensive. 1gal oil 24.95 plus filter.where I work we use lucas in higher milage engines to help with engine noise. seemed to work pretty well.so i thought i would try it in my bike. I was taken back by the improvement of the shifting quality and how it quited down the engine.even on hot days engine and trans do very well. I didn't intend for my experience to be a fix all.this my be unique to my bike.I have put 10k trouble free miles on my bike with no clutch,engine or trans related failures.no starter problems either. this was a bike I was told by 3 different mechanics would need major work to be reliable.that was 14k ago. once again I'm sorry to those of you who are having problems.
