'CHROME' Powdercoat
    'CHROME' Powdercoat
    I just got done powdercoating some bits with Eastwood's 'reflective chrome' powdercoat. Not bad, but if you're expecting a realistic 'chrome' you can forget it. This looks exactly like the 'chrome' paint you can buy, or like polished aluminum with a slightly milky clear over it, but the upside is it doesn't mar/fingerprint/dull like the paint does, is as tough as any powdercoat is, so it's a lot more durable.
    This will show any defects in the part, so prep is important. For some reason, it tends to 'mottle' just a bit on cast iron/steel parts, but works well on sheet metal. I haven't tried it on aluminum (that I polish).
    Eastwood does offer 3 'grades' of this (85, 90, and 95% 'reflectivity'), and I used the 85% kind. The difference is the two higher ones require a clearcoat over the 'base', the stuff I bought is single-stage. $15 for 8 oz, and this will do a bunch of parts. If you don't want to spend a ton at the platers, this is worth a look.
  • thebottle
    • 158
    • Wisconsin
    There is almost no chrome shops in my area. You can check my thread where I painted and clear coated my engine and I was looking to chrome the engine covers. I had only one chrome shop in my area and they never got back to me after repeated messages. I found out that there are a million regulations for chroming in place by the DNR in my area and that is what makes it so expensive. So I have decided to change the look of my bike by going to flat black and gloss black like someone else on here has posted as their bike. I fell in love with it. I don't know who it is or what the thread is, but I have the picture on my site. So if you see this, just know, this is the inspiration for the look of my bike when I get it completed. Thank you.
    1980 XS1100SG
    1998 KLR 650
    • tinman905
      • Aug 2007
      • 946
      • Orangeville,Ontario ,Canada
      Ceramic chrome paint is amazing stuff . It is the next best thing to real chrome
      plating. You can do it yourself too or send it out it's not much more than powder coating .
      BDF Special
