Advanced Motorcycle bar risers and Grip Puppies
  • BossMaverick
    • Aug 2008
    • 130
    • Montana
    Advanced Motorcycle bar risers:
    A few weeks ago I saw XS1100 bar risers on ebay. It looked very nice to have but there was a bidding war and I lost at a high big. I started doing web searches for generic 7/8" bar risers. The majority of the risers only offer a 1" verticle raise. I finally found the Advanced Motorcycle products risers after I used many search engines. These risers raise the bar 1.25" and back or forward either 17mm or 25mm depending on how you position the riser. The only other risers that raised and brought the bars back that I found were around $100+. These are $65 shipped.
    The machining quality is very good but they leave the aluminum risers uncoated. I wish the risers were anodized so I wouldn't have to worry about corrosion but they seem to be doing ok so far. They fit well on my XS1100 and it includes new bolts. They don't plug the half circle left in the bar base but with my fairing I never noticed that. They also aren't the prettiest option but the comfort makes up for it. They do look better installed then how they look on the seller's webpage but they still look odd. After trying the differnet positions, I settled with the 17mm pull back. I find that I can ride all day without anymore shoulder or wrist pains. Plus, I find it a lot easier to do slow speed turns and U turns. I higher recommend risers if your having pains during longer rides. Looking back, I could have probably saved money and went for cheaper 1" risers (they would look nicer too) but it's nice to have the bars perfectly positioned. Advanced products takes a few days to ship but nothing unreasonable. They include very good instructions and respond fast to email.
    Overall rating: 9/10 (-1 for no paint or anodizing but overall a good product for the price)
    Advanced Motorcycle Products webpage: http://www.motorcycleproducts.org/ba...n-frameset.htm
    Grip Puppies from CA Sport Touring:
    At the same time as the bar risers, I was looking to make my grips more comfortable for cheap. I finally stumbled across the Grip Puppies. It is a foam grip sleeve that goes over your grips. It is advertised as being UV, ozone, and oxidation resistant. I ordered the small size and it came long enough that I still had to trim it to the correct length. They slid on tight but fairly easily with soapy water*. They appear to be a very high quality foam that will last at least a few riding seasons (probably for many years if your bike is garaged and not exposed constantly to the sun and elements unlike mine). It make the grips feel 100% more comfortable for me. The cost for a set is $8.80, which includes free shipping. They were backordered when I ordered mine so they were delayed about a week before they shipped. They do not say backorder status on the website but you can always call before ordering to check availbility.
    *My grips were pretty much worn smooth. I found that the grip puppies spun on the worn out grips after the soapy water dried. I had to use adhesive to get them to stop spinning. I don't think this would be a problem if you grips aren't as worn as mine. Just keep in mind you might encounter this problem so test before you ride.
    Overall rating: 10/10 (Awesome comfort, value, and quality for the cost)
    CA Sport Touring's website:
    1980 XS1100 Standard "Touring"
    Fairing, Trunk, and Bags
    850 FD
    Fork Brace
    Progressive Front Springs
    Engine Guards w/Foot Pegs
    Oil Cooler
    Throttle Lock
    Uni Air Filter in Airbox
    2009 Suzuki Bandit 1250S ABS
  • BossMaverick
    • Aug 2008
    • 130
    • Montana
    Bead Rider seat cover
    I forgot to include my Bead Rider in the original post.
    Bead Rider:
    Bead Rider is a slip on seat cover of wooden (or ceramic) beads. I'll be honest and say that it doesn't sound comfortable but I had originally bought one for my previous bike, a 250 street bike that made my butt cry after 100 miles. It made a night and day difference on that bike in that my butt would be ok until 150 miles (I would get sharp pains after that). I just got a Bead Rider for my XS. Before, I would get numbing after a couple hours in the saddle. I don't get numbing at all anymore. It's very comfy now. Another good side effect of the beads is increased cooling on hot days. A pro or con (depending on how you feel about it) is it also is easier to slid to throw your weight around in curves. I like to be able to slid easy but others may not. Cost for the "Classic" (wood) Bead Rider is $35.95 plus $10 shipping. Cost for the "Ultimate" (ceramic) Bead Rider is $55.95 plus $10 shipping. I went with the Classic and haven't had problems with it.
    I'd highly recommend the bead type of seat cover for those that get numbness that goes alway after standing for a minute or readjusting in the saddle. The Bead Rider keeps blood circulating and prevents the numbness. I would not recommend the bead type of seat cover if your having sharp tailbone/spine pains. You would probably have better luck with gel, air, or sheepskin covers if your having sharp pains.
    Overall Rating: 10/10 (Good quality, good value, great comfort)
    850 FD
    Fork Brace
    Oil Cooler
    Throttle Lock
    • pinkelephant
      • 71
      • Effingham, IL
      I used to work in the biggest bicycle shop in Houston in the mid 80's. (Daniel Boone Cycles). we used to use generic hair spray arisol cans to put on grips. Just spray some inside and it makes it slick as WD40 when putting on and when it dries, it stays put.
      • MindWebs
        • May 2009
        • 431
        • Baldwin, WI
        and hair spray gets slick every time it gets wet.
        i've used spray paint on many sets of grips.
        spray on bars, slid your grips on, let dry over night.
        and rain won't effect it.
        • LoHo
          • Sep 2002
          • 1342
          • Fresno, CA
          A few years ago one of the bike mags did a comparison of the new gel seat covers and threw in the beaded seat as a joke. The beaded seat won hands down for long distance comfort. The long slab runs are the killer for my butt; the shifting around in twisties seldom affects me. I plan to give the beads a try on my next long trip...if I ever have one...
          • MeatTooth
            • Apr 2009
            • 175
            • Tulsa, Oklahoma
            I've also used spray paint on all my motocross bikes since I was a kid.....but the last bike I had I tried it (2003) and after about 30 minutes of the grips being on they split and fell off the handlebars! I think the chemicals in the paint attacked the rubber in the grips.
            Tulsa, OK
            • Blueiguana86
              • Oct 2009
              • 13
              NO NO NO NO dont use any type of spraypaint or any thing from a can the best way is to simply use an air compressor there is no mess, there is no drying time. and who ever was the bike guy you guys at that bike shop have got to be kidding. i would never do that thats a horrible idea. me being a certified bicycle mechanic im just blown away that people do that. just stick with the compressor. will work better than any
