Electronic Flasher
  • Korr
    • Jul 2008
    • 293
    • Torrance, CA
    Electronic Flasher
    Got this info from Crazcnuk. I changed out my stock turn signals and they would no longer flash and am using single filament bulbs up front. I went out and bought a two prong electronic flasher from Kragen and now they work fine, but only if the bike is on. So give it a try if you're having problems after replacing your turn signals.
    1978 XS1100E Standard
    Tkat Fork Brace
    On Hold
    TopCat S.O.F.A. + Fuse Block
    Mike's XS Pod FIlters
  • XSrunner
    • Feb 2008
    • 97
    • Batemans Bay AUSTRALIA
    Hi .if you use the square electronic one (ep12 tridon brand) it will work at nine volts (11volts need for round one) so will work with only key turned on.
    JOHN'O
    Xs1100E 1978
    American Import Cruiser
