Dyna Coils
  • Pat Kelly
    • 3046
    • Golden Valley, AZ
    Dyna Coils
    The right coil (cyl 1 and 4) stopped firing. I put new coils (Dyna
    Coils) on my bike. I also got the 8mm Dyna wires. After installing
    them I found I still had no spark at the same coil. Wires were good
    from coils to ign box and from ign box to connector behind fusepanel. I
    didn't get around to checking the pulse coil to the connector when a
    different ign box arrived from an Ebay purchase (I hope $20 wasn't too
    much for the box). Turns out the box was the problem all along.
    Anyhow with the new coils in, new plug wires, Bosch Platinum plugs
    (gap increased to .35") the bike has significantly increased power.
    A sharp roll-on in 1st gear at about 20 MPH (not popping the clutch)
    had the front wheel hovering just off the ground for almost a block.
    I currently have the Pacifico fairing off, the saddlebags too.
    This is a power upgrade I'd recommend. I did take step by step
    pics...but my 2 year old got ahold of the camera and deleted the
    first half the pics. If we'd like the pics and a "how to" write-up
    I'll take the coils back off and redo the pics. I did some modifying
    for the mounting, the pics would show why I chose to do what I did.
    I see around the corner from me is a trailer with a portable
    motorcycle dyno. I may call them and see how much to see what kind of
    power I'm working with. Has anyone else dyno'd their bike?
    I broke the middle finger on my right hand last week.
    Throttle/braking is great therepy.
    Let me know on the pics...
    Pat Kelly
    <p-lkelly@sbcglobal.net>
    1978 XS1100E (The Force)
    1980 XS1100LG (The Dark Side)
    1999 Suburban (The Ship)
    1994 Dodge Spirit (Son #1)
    1968 F100 (Valentine)
  • CA.XSer
    • 189
    • Jerome, ID.
    Pat
    Don, the owner of Modesto Buell on Carpenter Rd has a dyno that is in a trailer. Not sure where he lives. Had my 79SF done last year by him. Not sure what he charges, but if you catch him when its setup for a special day at his shop it is cheaper. I paid $20.00 to have mine done. Modesto Buell was having an open house/dyno shootout that day. Here is a link to my dyno printout.
    Gary
    79sf
    78e
    • sixtysix
      No XS but XSive as can be!
      • 1958
      • Central New York State
      Pat,
      I you want to retake some (a few is all you need) and send a write up to me in word or just text and pictures, i can get it posted in the tips section. even a write up with a final picture would be nice. Thanks!!
      Gary Granger
      • briguy66
        • Dec 2010
        • 13
        • KCMO
        Dyna coils
        Has anyone else experienced an ECU (ignition black box) failure after upgrade to the Dyna 1.5 Ohm coils? May just be coincidence but when starting the bike my understanding is that the extra 1.5 resistor is bypassed. Just a hunch but mine failed shortly after installing the 1.5 coils. Going with the Dyna 3 ohm coils and bypassing resistor may be a safer play to not potentially fry a good ECU. Luckily I had a spare.
        1980 1100 special
          • 4006
          Hey Bri-
          Your understanding is incorrect. The stock coils are 1.5 ohm coils, and you replaced them with Dyna coils, which are also 1.5 ohm coils. Therefore, the ballast resistor should remain.
          If you replaced them with the Dyna DC-1 coils (3 ohm), you would then remove the ballast resistor.
          • Pat Kelly
            • 3046
            • Golden Valley, AZ
            Update,
            Bike still running, just don't ride very often anymore.
            Bike now needs work done from sitting so much but no time or inclination to work on it.
            But it sits, ready and able when asked.
            Pat Kelly
