I just bought a 1980 eleven special, with Kerker pipes. I can't find any info on these pipes anywhere. Has anyone ever used these pipes on their bike? What advantage, if any, do they give over stock pipes?
Kerker Pipes
The Kerker pipes are considered to be amoung the better performance pipes on the market. As with all 4 into 1 systems, you loose the weight of the 2nd muffler and gain some ground clearance. Generally the carbs need to be re-jetted to take advantage of the scavaging and higher-end flow of the system. Check your plugs for color to make sure the PO did the job right. Typically the Kerker improved mid and top-end performace at a slight loss of low-end grunt. Performance also will vary depending on which muffler you use. The sound is also different than a 4 into 2 system.
Drawbacks include - on some models - restricted access to the oil filter and inability to use the center stand, which must be removed to install the exhaust system.
The Kerker is a good system, particularly if the carb jetting has been set to match.Jerry Fields
'82 XJ 'Sojourn'
'06 Concours
My Galleries Page.
My Blog Page.
"... life is just a honky-tonk show." Cherry Poppin' Daddy Strut -
Thanks for the info. I do seem to be lacking a little bit of low end power, but once it hits the powerband, we're off! I read somewhere else about the center stand needing to be removed, but mine is on the bike and works just fine. As soon as I get a chance I'll have to check out the plugs. I was told the carbs were re-worked right before I bought it, we'll see.I know this, because Tyler knows this.
1980 SG
3J6 003509
Kerker 4-1 (sans baffles)
Fuse Block Upgrade
Mike's XS Green Coils
Pods w/Homemade Velocity StacksComment
