I have a 1985 honda magna 700...both front brake calipers are sticking ..almost to the point of locking up the wheel...I have taken apart both calapers and cleaned them..bleed the brake system..seens like nothing i do helps....anyone here know anything about these bikes..and what i could do to fix the problem?...would the problem be in the master cylinder?
Honda magna front brake problem
Tags: None
Sounds like the "spooge hole" problem the XS's have.Pat Kelly
<p-lkelly@sbcglobal.net>
1978 XS1100E (The Force)
1980 XS1100LG (The Dark Side)
1999 Suburban (The Ship)
1994 Dodge Spirit (Son #1)
1968 F100 (Valentine)
"No one is totally useless. They can always be used as a bad example" -
Check the MC
I would say that your Mc is plugged up. As the prevous post states there should be two small holes in the bottom of the MC resivoir. The one hole is easily seen the other is a tiny little hole that is easy to miss. Make sure both holes are cleaned out and brake fluid travels threw them and you should be in good shape. This should fix the problem!!!Dan ( A.K.A.- MacGyver )Comment
