XS 750 Special mufflers
  • CUBuffs
    • 252
    • Castle Rock, Co
    Is it possible to replace the mufflers on a 79 special without having to replace the pipes as well? The pipes on my bike are in very good shape but the mufflers are rotting through the bottoms.
    80 XS11 SG
    79 XS750 SF
    74 KZ400
    78 KZ650
    78 KZ750
  • bandet01
    • 698
    • connersville indiana
    i think they make some repleacement slip ons but i dont think there factory style but the 2 companys that i think that make then are jardine and mac
    79 yamaha xs1100f standard
    best 1/4 mile 13.282@99.40
      • 7828
      CUBuffs,
      I think there is a thread on replacement mufflers. If you can weld, you can put a pair of HD mufflers on the XS. The best part is all the HD people throw out the stock muffler, and they can be had cheap.
      Ray
      • webbcraft2150
        • Sep 2002
        • 1605
        • AUSTIN.TX
        I replace the mufflers on my 80g with a pair I bought from JC Whitney. They have a large selection and the prices are not bad. They are the same brand of "universal" mufflers Dennis Kirk and Chaparrel sells. They have different lengths and you should be able to find a set that will stop where your stockers did. I did have to get an adapter from Pep Boys to make the mufflers fit the stock header pipes. Some minor modification to the stock hangers was also necessary. I fabricated a stop for the center stand. One thing to watch out for when you modify your stock hangers is to make sure the mufflers clear the swingarm and your brake pedal when you bolt them up. All said, it was not a hard project and ran about $160 for both mufflers and the exhaust pipe adapters. Exhaust note was ok and seems to have improved with use, not loud but they dont sound like a runaway outboard either.
        • JWSanders
          • 879
          • White House, TN
          Mike's XS has a decent supply of slip-on mufflers as well. Around $40-60 each.
          80 XS1100SG
          81 XS400SH
          Some men miss opportunity because it is dressed in overalls and looks like work. - Thomas Edison
          A Few Animations I've Made
          • CUBuffs
            • 252
            • Castle Rock, Co
            Gents,
            Thanks for your suggestions.
            80 XS11 SG
            79 XS750 SF
            74 KZ400
            78 KZ650
            78 KZ750
