Is it my stator?
  • joshlikessurfin
    • Jun 2005
    • 15
    • Austin
    Yes. I am trying it with the key on. And the kill switch is on too. Yeah, maybe it is not a short, or maybe a partial short? But not enoughf to blow my fuse, just enoughf to draw to many amps.
    • randy
      • Dec 2003
      • 4521
      OK,
      I think you missed some good advice from Geezer
      Have you tried it with the regulator/rectifier unplugged?.
      Unplug both of the plugs at the reg/rec and try to start it. If you don't get spark, start checking your ignition system.
      • joshlikessurfin
        • Jun 2005
        • 15
        • Austin
        Got it fixed
        Looks like the problem was two lose fuse connections. That got my electrical to work ok.
        Tha main problem, One coil was bad. Also my ignigtor was fried. I think one went then killed the other. Found the problem by checking spark (got spark back after i fixed the lose conection). Only half my plugs fired. Switched the wired to the coild and nothing worked. So my ignitor only worked for one coil conection and one of my coils was bad.
        THANKS GUYS FOR ALL THE HELP
        • randy
          • Dec 2003
          • 4521
          joshlikessurfin;
          If you'd like your ingitor fixed, PM me and I'll reply with my address. Always good to have a spare.
