Yep, pretty much the same as XS11 carb hell.... In the beginning, carbs were completely stripped and soaked, and passages blown out with high pressure air. After getting the m/c on the road, I noticed #1 header pipe turning blue, indicating to me that it was running lean. Took carbs off and proceded to measure fuel level (OH BOY!!! I smell like gas again!!) Discovered the screw that holds the needle seat in place had came right out on #1. So, I put it back in and made sure it was tight this time. After adjusting the floats as necessary to bring it in line with factory specs, I reinstalled the carb bank. Resynced the carbs and thought everything was fine. Wrong. Getting a steady seapage from #1. Very strange because the body of the carb is wet with gas ABOVE the float bowl. Am I looking at carb kits, or bowl gaskets?
Any thoughts?
Thanks
Brian
Any thoughts?
Thanks
Brian
