I have a '79 xs 400 which uses Mikuni CV carbs. For the longest time I thought that the lil' pilot screw actually controled a flow of fuel mixture through the little passageway it opens and closes that comes from inside the carb.
I now think that hypothesis is wrong.
Maybe I am crazy, but is the princple of operation instead controlling a vacuum of air which pulls up the diaphragm, the slide it is attached to and thereby richens the fuel/air mix while the throttle is otherwise closed (open only as slightly as the throttle stop is set to)?
If I am correct, then it would indicate that the function of idle is also affected by the smoothness of the slide, the pliability of the diaphragm as well as the relative clip position of the needle. Would also explain the need for the three position choke a little better...
Thanks for the clarification.
-Patrick "Using The Ol' Noggin', Or Is The Noggin' Using Me?" Kennedy
