The bike has sit for most of the time I've had it because it never really ran quite right. The bottom end has always been dead as a rock...I have to rev it up to about 3-4k and/or very slowly let out the clutch for it to even go without dying. Once it gets going, however, watch out! I can pull wheelies on this thing easily, at least in first gear (never attempted any more). I just adjusted the float and raised the fuel level, and it seems like it didn't help the bottem end problem (I thought the fuel might not have been getting to the pilot jet which is set a little higher than the main), and it actually hurt the high rpms where it seems like it has a rev-limiter or something.
I haven't changed the spark plug, but it looks okay, and the gas in the tank is about 3-4 months old, but it was always in a good location (basement...consistant temperature). I drained the gas before, and it didn't help then either.
Thanks to any help!
Kevin
P.S. the carbs seem to be as clean as a whistle! I've cleaned them a couple times, and the fuel seems to go wherever it should (I don't reallly know how much should flow through, however...I suppose some might be restricted, even though they seem fine.)
Thanks to any help!
Kevin
