Well, it seems that if it isn't one thing, it's another lately. When I was in Picton last weekend, the starter switch (or so I thought) started acting up and only working occasionally. No problem I thought, I'll just clean it when I get home. Switch has been cleaned, wiring checked, and I have power all the way to the starter solenoid when I hit the button. But.. the starter won't spin. Check the solenoid, no power coming out of it when I hit the button. Aha!! the soldenoid must be bad. Managed to find a suitable replacement.. fab the wiring so it will connect, install both cables on it, hit the button and listened to absolutetly nothing. Just the clicking from the starter circuit relay. Still have power to the solenoid, still have no power coming out when it won't start. Heading further downstream to check the cable at the starter and the main ground cable.
The really strange part is that I can short across the posts (battery to starter) and the bike will start. And if I repeatedly hit the starter button, it will eventually spin over and start.
Any ideas are greatly appreciated.
2nd problem that reared it's ugly head was the right side exhaust breaking in front of the muffler. Anybody have a good used one, stock or otherwise? No aftermarket or stock systems are available in Canada... stock is available in the US, but only as a last resort.
If I can find a good set of header pipes then the slip-on mufflers are not a problem.
