Triumph: Switched Relay Splitter
    • 4011
    Howdy. So, the setup right now is a terminal strip block coming off the battery via 8 awg wire (positive and negative). One half is negative, the other half is positive.
    Coming off of the positive half are six or seven in-line ATC fuse holders, going to six or seven individual relays (also having switched power fed into them), which in-turn feeds power to my numerous accessories.
    The goal: clean it up. It's a lot of wire under the seat, which also means many points of failure. First thing I will do is swap-out the terminal strip block for a ATC fuse block (like what TC sells for the XS). Then, I'd like to use the terminal strip block for grounds only, or taking everything to the battery.
    I guess there is no way to get away from using so many relays, which is causing a lot of the wire mess.
    Any ideas would be welcome.
    Btw, everything that has been added needing a relay includes:
    Voltmeter
    Fuel Computer
    DC Cigg. Adapter
    LED Foglights
    HID headlights
    Scorpio Alarm
    Adaptiv TPX Radar Dector
    • 4011
    Let me ask this:
    Okay, this may sound bizarre, but hear me out for a second:
    If I had a single relay with the battery ground going to #85 on the relay, battery + power going to #30, switched power from a lighting circuit going to #86, then the output of #87 going to a fuse block, which I would then send the output of every fuse to the accessory's positive connections, could I get away with using only one relay for all of my accessories? I believe the relays are 30 amp relays. I'm wondering if the draw will be too much on that circuit, using just one relay?
      I'll work for a while but it's not what you want, Ian.
      Fuses are basically resistors. Resistors in parallel are not a good idea for fuses and putting the output of all the resistors onto one wire to run everything is an even badder bad idea.
        • 4011
        Noted. So, looks like I have to stick with multiple relays. Okey dokie.
          Well, stick with the correct, multiple, fuses for the circuits and don't twist 'em all together.
          What kind of Trumpet are you playing with? You may be able to get rid of a few relays and clean up the wiring but it'll change the fuses you have to use when you combine circuits. Try not to put a low-current circuit with a higher one on the same fuse and relay or vice versa.
            • 4011
            My Daytona 955i Centennial Edition:
              Ooooh! Yeah!
              Ian, that's, like, a fine piece of performance art there!
                • 4011
                Lol! Thanks. It's a fun bike.
                  Ian,
                  You have the makings of a museum in your shed
                  Of course you might have to keep some of them for a few more years
                    • 4011
                    Ian,
                    Lol. 3 garages worth of bikes. 29 bikes.
                      • 4011
                      So, ran this setup by an electrical engineer at the shop today, and he says to fuse the relay, and I should be good to go on the setup I have in-mind. However, he also referred me to the following, which I thought was pretty cool:
                      http://www.easternbeaver.com/Main/Wi...PC-8/pc-8.html
                        Nice links, I like the boxes! Your EE friend is correct, of course and fuses are supposed to be put in series with whatever they're protecting.
                        I took a quick look and found Triumphrat.net. There's no schematic or srvice manual at this link but the folks seem clueful:-
                        I have no idea how the relays and other circuits on your bike were done or who designed the electrical system for Triumph. Control circuits can get complicated and I don't even want to type the "L" word for one notorious British company.
                        Since you're changing the wiring/relays:
                        You can use two fuses, one low-current fuse for the relay coil and a larger fuse to protect the load.
                        You can tie the relay coil to the load circuit's fuse.
                        You can fuse only the high-current load and let the relay coil hang ten like Yamaha did for the XS1100 Headlight relays by feeding it straight off the alternator.
                          • 4011
                          So, the boss says to fuse the relay, then the switched output of the relay would be okay to goto the fuse block.
                            • 4011
                            Everything I'm doing is coming off the battery to power the relays and accessories.
                              If you don't have one already, find a factory service manual and the wiring diagrams.
                              Keep in mind that newer vehicles have computer controls can be very temperamental and expensive to replace. There can be subtle anti-tamper designs and circuits alongside some not-so-subtle anti-theft circuits that require a dealer to unlock.
                              Just be careful, even the most basic circuit design discussions can get very close to arguments empirically specifying beer, wine, ale, or whisky as the correct beverage to serve with your haggis on Burns' Night:-
                              Whisky may be the traditional tipple for Burns Night but if you prefer red wine here are the ones that I think work best with this spicy scottish sausage
