01' Kawasaki Vulcan 800, spark plug socket
  • Jbird427
    • Apr 2011
    • 10
    • Bessemer, Alabama
    i have a 2001 Kawasaki Vulcan classic 800. It doesn't have the original tool kit and I need the spark plug socket to change the spark plugs. I can't find this socket anywhere (eBay,bike bandit,Amazon). If anyone knows where to get one please let me know.
    JBird427
    79' xs1100 special
    06' Honda shadow 1100
    Not born, Not bred... Self-made Biker
    79' XS11 Special
    06' Honda Shadow 1100
    JBird427
    79' xs1100 special
    Hi Jbird,
    If you just need to change the plugs you should be able to use a regular sparkplug socket available at most automotive stores.
    http://www.harborfreight.com/catalog...arkplug+socket
    Often included in socket sets.
      • 8923
      According to specs your bike uses a NGK CR7E spark plug which would be a 16mm (5/8") hex. Is the problem you are having is that the socket is too fat to fit down the tunnel?
        • 7828
        The R1200RT needed a "special socket". I went to harbor freight and picked up a LONG 5/8" plug socket. I then took a grinder to the outside and thinned it down a bit so it fit into the DEEP plug wells of the BMW. It should work for your bike as well. Cheap, easy fix.
          Hey J Bird,
          You have to check back for the answers to you question
          I checked with a friend who has a Vulcan 800. Yes your plugs are down a hole.
          Apparently easier if you take the tank off to get to the rear plug.
          Lots of help and advice ( like here) at http://www.vroc.org/
          The skill testing questions for admittance are:
          What do you ride & Where do you ride it.
