XJ550 float level
    XJ550 float level
    Anyone know the float level setting on an XJ550?
    • 8922
    This is taken from the XJ550 Clymers...
    Use a piece of clear vinyl tubing with an inside diameter of 0.24
    in. (6 mm). The tubing should be long enough to
    reach from one side of the carburetor assembly to
    the other.
    After the carburetor assembly is level hold the
    loose end of the tube up against the No. 1
    carburetor body. Check the fuel level in the tube. It
    should be 0.079 ±0.039 in. (2 ± 1mm) below the
    top surface of the float bowl.
      • 2101
      Scroll down to the last page of this link and it has model specific float levels.
      And bikerphil is spot on as in they are "wet set"
        Thanks but I already found that. I was wondering about the initial FLOAT level. I don't want to take these things back apart 50 times to get it right.
        And those fuel level specs don't specify whether that's above or below the gasket.
          • 2101
          This link states a 21.5mm dry height for Mikuni BS28 carbs which, from what I've researched should be on the XJ550.
          http://xjbikes.com/forums/index.php?...burator.39380/
          What year & model ?
          I believe the wet height is set accordingly from the edge of the carb body.
            Thanks, that's what I was looking for.
            It's an 82 550 Maxim.
              • 2101
              Greg, the dry height is set with the carbs tilted at an angle that allows the float tang to just come in contact with the float pins anti-shock mechanism.
                I've tried it that way before and I've ended up with flooding problems. I have better results with the carbs inverted. We'll see.
                  • 2101
                  Just repeating what was stated on the XJ site, but now that you've mentioned it, you'd think that procedure would set the fuel level lower as the floats would be measured higher, but the valves need some pressure to seal which demands more movement of the float so I can see where a raised fuel level may result.
                  Honestly, I don't recall ever reading the tilted carb procedure til today and I believe I've set all floats to date the same way you have . . . must've 'cause they all run fine.
                    Yeah, I got the same info on an XV1100 Virago I was working on and set the floats that way. Had to pull the carbs again (a real PITA on an XV) and reset them inverted.
                    • webbcraft2150
                      • Sep 2002
                      • 1605
                      • AUSTIN.TX
                      The "wet set" process is truly a pain in the arse. Being a fan of shortcuts, I did the wet set on one carb on my "free" '82 550. Once I had the one float level dialed in, I set the other three to the same measurement (which I did not write down). Reassembled the whole thing and fired 'er up. Synced the carbs after I figured out that YCIS caca. Idled good, ran good, was pretty dam spry for a 500 I must say. Plugs reading just fine so maybe I got lucky on my shortcut.
                        Thanks Keoki, thanks a lot for not writing it down.
                        I'll try the 21.5 on one and check it with the tube. That sounds about right for these 28mm carbs.
                          Another question. I got the floats set pretty good and it runs pretty good in the garage.
                          Do any of you out there HAVE an XJ550J? I need to know what the battery box is supposed to look like installed. Pics would be much appreciated.
                          Also, I need a rebuildable front master cylinder, and a right side cover. Ebay is pretty slim on those things at a decent price.
                          • jwhughes3
                            • 2798
                            • Home of the Alamo
                            Greg that master cylinder is bad? On the XS400 I used one from MikesXS and it worked fine.
                            There were two covers in the lot. Keep looking.
                            John
                            '81 XS1100H - "Enterprise"
                              Yes, it's bad. Frozen. It's an aftermarket MC anyways.
                              I'm fixing it up for my nephew and I want it as original as possible.
